Results 1 to 1 of 1
Thread: an oscilloscope as TTL signal source?
    Sep 2007
    Hi I am a self learner and my question may sound clueless but I'll give a shot anyways.
    1.
    Can I use an oscilloscope or any pulse generator as a pulse source to control any given servo controller with TTL TX RX port, as long as the oscilloscope or the pulse generator generate compatible and meaningful binary TTL pulse sequences?
    2.
    Should the TTL communication be bi-directional? (the controller has TX and RX TTL port) In other words, does the oscilloscope also need to receive and acknowledge pulse coming from the servo controller board? Or would it work just fine in one-way?
    3.
    Is it possible to daisy-chain multiple TTL-controlled boards under an oscilloscope or a pulse generator as long as each board is set to different address?
    Thank you in advance.
  1. Recommendations for Oscilloscope
    By 123CNC in forum General Electronics Discussion
    Last Post: 09-07-2007, 11:58 PM
  2. How to use an oscilloscope
    By bgolash in forum General Electronics Discussion
    Last Post: 05-02-2007, 06:46 PM
  3. Soundcard oscilloscope?
    By phantomcow2 in forum General Electronics Discussion
    Last Post: 02-20-2007, 05:56 PM
  4. How often do you use your Oscilloscope?
    By murphy625 in forum Polls
    Last Post: 02-16-2007, 06:50 PM
  5. oscilloscope Help!
    By miljnor in forum General Electronics Discussion
    Last Post: 09-12-2005, 07:43 PM
