Results 1 to 5 of 5
Thread: using servo motors
    Feb 2007
    canada
    using servo motors
    I'm hoping some people in here can help me. I am a furniture builder/artist that has designed a few pieces of furniture that I want drawers to open/lids to close/screens to pop up and various other things that have some weight involved with them. Are servo motors the way to go and can anyone give me a heads up on even where to begin my research on this. I have asked a few shops that sell motors to start but had no luck. Most people just look at me like I'm a little nuts but its doing essentially the same thing as what a cnc machine would use the motor for so I thought I would have a better response here....thanks
    Jeff
    TwoBitDesign
    Jun 2003
    Boalsburg PA
    if you just want to have the moving parts to go from one stop to another, a dc brushed motor is the way to go. You just need a dc power supply and two limit switches driving a couple of relays.
    Dec 2003
    Although not a fan of steppers, depending on the speed and the mechanism you are using, you may be able to use ordinary stepper motors in the synchronous mode of operation off of AC direct, no power supply or drivers, Transformer & AC rated capacitor only, unless you go with 120v types, then you don't need a transformer, the down side this will be one speed and fixed, but immediate stop start.
    Or following the suggestion By Unterhaus, a way with a DC motor would be Scrap Auto Wiper motors mechanism and drive, very powerfull linear drive.
    Mar 2003
    Shelby Twp, MI....USA
    How about these guys. http://www.inca-tvlifts.com/
    Downside is that they are expensive.
    Al, you could always gear the AC steppers to give the speed you want, right?
    Dec 2003
    Quote Originally Posted by ger21 View Post
    That true, but unfortunatly with 1.8° steppers you only get 72 rpm on 60hz, so there is not much room to play with. Depends how their used I guess.
    1. Where to buy DC servo motors?
      By Neil_J in forum General Metal Working Machines
      Last Post: 03-06-2006, 03:17 PM
    2. Are these servo motors
      By George in forum Servo Motors and Drives
      Last Post: 02-22-2005, 10:11 PM
    3. DC Servo motors
      By osdhillon in forum Servo Motors and Drives
      Last Post: 01-25-2005, 04:59 PM
    4. servo motors ?
      By vertcnc in forum DIY CNC Router Table Machines
      Last Post: 12-19-2003, 10:53 PM
    5. Getting into servo motors
      By jimglass in forum General Electronics Discussion
      Last Post: 06-02-2003, 04:36 PM
