Old 01-27-2007, 12:03 AM
rkdygert is on a distinguished road
Need drive for CHNC spindle motor
I am trying to figure out the best way to retrofit my CHNC lathe and am stuck on how to drive the spindle. I would like to keep the original spindle motor as it was just rebuilt. It is a DC PM servo motor, specs are:
Model: 193-18-0025-0
Frame: NR00166
Encl: T.E.N.V.
Duty: Cont.
Ins.Cl. H
Torque 242
RPM 0
JA-LB.IN.SEC.2(squared) .295
Max RPM 3500
Max Volts 118
Max.Arm.Pulse Amp. 1094
Tach. 31.5 Volts/1000 RPM
Spec. IFC 34-1 (1969)
Data Sheet K-8722
BR. Volt. 90 D.C.
The exisiting AB control uses a GE PWM to drive the spindle. I want to update this with either another PWM or else a servo drive.
The existing drive ouputs 90V at 85A to the spindle motor.
If anyone can direct me where to look for a compatible drive that will work with Mach3, I would be very appreciative...
Thanks,
-Ryan
[IMG] code is Off
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 05:51 PM
GE spindle drive 69owb General Electronics Discussion 6 03-20-2008 12:27 PM
spindle drive mark c General Electronics Discussion 10 04-12-2005 09:53 PM
Could one of these be used for a spindle drive Stevie General Electronics Discussion 1 01-25-2005 10:13 PM
