01-06-2007, 03:28 PM
Omron 500W AC Servo driver for robot setup | | I have a 6 axis welding robot that I want to use for a plasma cutter application. I have a little knowledge with cnc using a stepping motor but none about how to run ac servo motors or how to use G code and make this unit work. All I have is the robot arm. No control box or anything to run the motors with. I have removed the miller mig welding attachment and now need a idea of what drives I can use to run these ac servo motors.
2 of the motors are as follows:
W-L00180 FMA-50030-B0S1 500 W 3000 Rpm Omron Tateisi Electronics
S/N 111382
Any info would be great. jj. Fort Worth Texas
Reason: Adding more info on the AC servo motor
