| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
I want to do equivalent servo system of 200 step/rev step motor. (Stepper motor will work full step mode) I will use DC brush type servo motor and PID controller. I want same step responce by step motor. How i can choise encoder. (I will use x4 mode) 50 ppr encoder enough if we think simple . But i think i need minimum 500 ppr. May I learn your ideas? |
| 50 ppr at 4x is just OK for 200 steps/rev stepper in Full step mode. What will happen when you try to do half stepping or micro-stepping? You wont get any feedback until a full step position is reached. If your design can work with +/- 1 full step error, then 50 ppr is OK. If you want to minimize the error you will need a lot more pprs. If you want to get a smooth movement you will need the equivalent to 8 to 10 micro-steps/step minimum. 10 micro-steps => 2000 ppr(at 4x) => 500 ppr encoder. |
| I will give one full step puls to step motor and i will measure the position change by time. (I will use too sensitive position sensor for this examination) (Normaly i expect dumped vibration) After i will do same test by servo motor. Step motor and servo motor must give me same response. I think PID controller notting do with 50ppr encoder at this condition. 50 ppr give very bad results. (my idea) |
| Using the 50 ppr encoder you can expect a +/- 1.8 degrees error in positioning (+/- 1 step) due to the limited resolution of your sensor. Using PID will do nothing to improve that error (garbage in => garbage out). As I wrote before, you will need at least a 500 ppr encoder in order to see better results. |
