Old 08-05-2006, 05:59 PM
elalto is on a distinguished road
Question for AL "The Man"
Hi Al,
I have three new servo motors that I hope to use to convert my X3 size mill, problem is I can find no specs on the motors. The motors have the following data on the label:
Model # E660
Part # 0660-04-076
"1/4 HP PWM"
Can you help me out?
Thanks,
Marcos (elalto)
Old 08-05-2006, 06:47 PM
Al_The_Man's Avatar
Reliance/ElectroCraft had both Brushed and BLDC motors as E type, I don't show anything for E660 in either unfortunately.
Sometime a OEM number was used when supplied to large purchasers.
Is it Brushed or Brushless?
Old 08-05-2006, 10:06 PM
snakebit95 is on a distinguished road
I have a little bit of information that I found for this motor during my searches. Hopefully it will help:
Reliance Electric DC Servo motor
Reliance Servo Products
NEMA 34 Frame
Model 0660
Back EMF Constant, ke = 65 V/kRPM
Torque Constant, kt = 5.5 lb-In/Amp
Nominal Speed Rating: 1750 RPM
Nominal Voltage Rating: 120 Volts
De-mag Current: 40 Amps
Motor Body Diameter: 3.38"
Motor Body Length: 6.75"
Shaft Diameter: 0.375" x 1.13" Long
Mounting per NEMA 34
(4) 0.225" Holes on 2.75" Square Centers
Integral Encoder: Agilent / Hewlett Packard
500 Line yielding 2000 Counts/Rev.
Encoder is mounted under protective steel cover on tail end of motor.
Old 08-05-2006, 10:08 PM
Al,
I guess we will eventually have all the specs for all the Electro-craft motors listed on the Zone.......ahh?? LOL
[IMG] code is Off
