| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
If a motor has the specs. below what specs. are needed for a driver and if you were setting up the driver for this motor what continous current would you set it at and what voltage would you run the motor at? I have a 36v power supply. If this motor was runnig on 36v what type performance can I expect as far as wattage and rpm is concerned? Continuous Torque: .4Nm/57oz.in. Peak Torque: 2.83Nm/400oz.in. Speed at terminal voltage: 4000 Terminal Voltage: 60v Continuous current: 3.7 Peak Current: 25.9 Torque Constant: .1213Nm/A 17.1oz.in./A Voltage constant:12.7 v/KRPM Iductance: 6.4mH I am trying to learn the servo side of this CNC stuff a little better and it amy also help some others. Thanks Tommy |
| Speed calc as follows: (36/12.7)*1000 = please do the math Torque will depend on how much amperage you can provide. If you an provide the continuous current spec noted, you should be able to realize the continuous torque rating. The following may help Servo amp P/S design http://www.elecdesign.com/Articles/A...7635/7635.html Servo motor , servo amp, powersupply sizing for CNC http://www.rutex.com/pdf/Mystique2.pdf To get peak toque (400), you need to be able to provide PEAK current (about 25 to 30 amp capacity peak with minimal voltage drop at that level of current delivery should suffice) Last edited by NC Cams; 08-05-2006 at 06:57 AM. Reason: MAJOR typos & dumbouts |
