| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Hopefully somebody here will have an older book to look this motor up. I have a Maxon motor p/n: 44.032.000-00.09-153 I have searched the web and emailed Maxon with no help at all. Even partial p/n searches turned up nothing. It is a small 32 mm diameter servo motor with a Heds 100 count encoder on it. Right now it is coupled to a 4 start, 8tpi, 18" long coated screw. Thinking about building a small router out of it if possible. Thanks.
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
| The motor is a special. I have contacted my maxon dealer for you and he is going to find out some info from the factory for you. I will let you know what I find as soon as I get a response.
__________________ "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't" Greetings From Down Under Dave Drain Akela Australia Pty. Ltd. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| I have had a reply from my distributor. They have contacted Maxon and have been told that it is an invalid part number. Can you check the part number and give me any other info you can read on the side of the motor. Cheers Dave
| That is the part number that is on the motor. I tried laoding a picture of it last night but the computer was giving me trouble. I will try posting it again tonight.
| I'd follow your sig line and take that label off. The part of the part number that shows is the same as the one on the sticker, but there may be differences before that. Does the yellow wire come from the encoder? |
| I took the label off and the number underneath is the same as on the sticker. The yellow wire is coming from the encoder, a Heds-5500 C11.
