Old 05-17-2006, 02:04 PM
spottiepop is on a distinguished road
Question Okuma Servo Motors
I have some motors that came off a R25 4axis lathe, the specs on the Z-axis motor are.
Type: BL-MH101E-20T
2KW 2000RPM CONTINUOUS 166V 8.4AMP 6POLE CLASS F
ENCODER: OKUMA ABS-FB-D2048
X-axis motor specs are.
TYPE: BL-MB75E-20T
1.5KW 2000RPM CONTINUOUS 164V 6.6AMP 4POLE CLASS F
I would like to know what kind off drivers I need to control these, are there any out there that won't break the bank? I would like to use these on a lathe conversion and possibly a plasma table or mill. I sure would appreciate any help the Forum could provide.
Old 05-17-2006, 02:11 PM
Al_The_Man's Avatar
What type are they? Do they have brushes? (DC). BL could mean brushless.
It looks like the encoders are 2048p/rev
Are you looking for step/dir drives or Analogue?
A-M-C is one source for various types of motors.
Old 05-17-2006, 03:25 PM
I'm told that they are AC brushless. I'm new to this and don't really know exactly what I need. I would like to use them if it's not going to cost an arm and leg to get them to work. I was wondering if something like MACHNC would run them or what would I need to do to run them from a PC. I know these are alot bigger motors than most are using on this forum but they are free and it would be a shame to see them go to waste.
spottiepop
Old 05-22-2006, 04:59 PM
I looked in the boxes I was given and found that the amplifiers or drives which ever they are called are there, what control software can I get that will talk to these, such as Mach or something simular? I will have 240V 3 phase power to test these out pretty soon. I was told that they were in working order when they were removed. I also found all the cabling and the CPU that the OSP 5020L-G control used. I noticed that this post has some traffic but not many replies, are there other forums where I could post and get more info.? I am finding that AC servos are not really for the DIY crowd, but I sure hate to give up on motors that are as strong as these.
Thanks, spottiepop
Old 05-22-2006, 07:55 PM
Al_The_Man's Avatar
The OSP 5020L was the Okuma CNC control which probabally makes the drives and motors proprietary, which, unless you can get hold of manuals to reverse engineer the motor/drive details, maybe a long haul.
There is virtually a guarantee that they will not be step/direction controlled.
AL.
[IMG] code is Off
