| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
| Half a dozen lines instead of one don't seem like too much. If you had a number of the holes to do on the part, you could put the lines in an incremental subroutine. For long-term use, maybe you could simulate G12/G13 by creating a macro with variables.
__________________ Software For Metalworking http://closetolerancesoftware.com |
| Here's an example I found at CNC Concepts ( www.cncci.com ). They have a ton of useful manual programming tips there. GREETINGS FROM SOUTH AFRICA! I HAVE RECENTLY STARTED PROGRAMMING IN MACRO B AND HAVE WRITTEN THIS PROGRAM TO CUT PILLAR HOLES, ETC IN MOULD PLATES. THIS PROGRAM CUTS A HOLE OF ANY DIAMETER AT ANY POSITION WITH ANY DEPTH OF CUT USING ANY DIAMETER CUTTER. THERE IS NO NEED FOR RADIUS COMPENSATION AS YOU CAN CHANGE THE CUTTER DIAMETER OR THE HOLE DIAMETER TO GET THE SIZE YOU REQUIRE. YOU CAN SET THE DEPTH OF CUT TO MORE THAN THE TOTAL DEPTH OF THE HOLE TO JUST TAKE ONE CUT. THE 180 DEG. LEAD-IN AND LEAD-OUT WITH A RADIUS PLACES LESS STRAIN ON THE CUTTER AS IT COMES INTO CONTACT WITH THE MATERIAL TO BE CUT. HERE IS THE PROGRAM : :8000(PILLAR HOLES) #100=1.0(CUTTER DIAMETER) #101=30.0(X CENTRE) #102=30.0(Y CENTRE) #103=0.0 #104=30.0(DEPTH OF HOLE) #105=50.0(DIA OF HOLE) #106=3000(SPNDLE SPEED) #107=500.0(FEED) #108=10(TOOL POS) #110=20.0(DEPTH OF CUT) G00G91G28Z0.0 G91G28X0.0Y0.0 T#108M06 G00G90G54X#101Y#102S#106M03 G43Z10.0H#108M08 N1WHILE[-#104LE#103]DO1 #103=[#103-#110] IF[-#104GT#103]GOTO20 G1Z#103F[#107/3] G03X[#101+#105-#100/2]R[[#105-#100]/4]F#107 I-[#105/2-#100/2]J0.0 X#101R[[#105-#100]/4] G00Z10.0 END1 N20#103=-#104 G01Z#103F[#107/3] G03X[#101+#105-#100/2]R[[#105-#100]/4]F#107[[#10-#100]/4] G00Z10.0 M09 G00G91G28Z0.0 G91G28X0.0Y0.0 M30
| Here is a link to a circle milling program its free . www.kentechinc.com/tip7.html
__________________ Tim |
