Resolvers are an obsolete technology. The unit outputs a sine wave. Because of low resolution, they are generally geared up from the servo motor.
Encoders output pulses, generally three channels. Two channels are used for rotation and one is an index pulse, once per revolution.
AFAIK, the servo amps for each type are different. You'll have to specify which to use.
LinkBack URL
About LinkBacks
