Old 03-30-2006, 08:38 PM
vertcnc is on a distinguished road
Sanyo p5 servo
Has anyone got the Sanyo P5 1kw servos from surplus center running. I am looking for drives to run these motors.
tim
Old 03-30-2006, 08:52 PM
ger21's Avatar
http://www.cnczone.com/forums/showthread.php?t=17227
Old 03-31-2006, 11:46 AM
KTP KTP is offline
Gold Member
KTP is on a distinguished road
Yes, as Ger21 pointed to in the other thread, I am using the P5 1kw motors on my cnc mill x axis (which has a 500+lb table) with a Pixie controller (www.skyko.com) and a analog input servo amplifier (similar to an AMC B25A20AC). My x axis rapids went from an unreliable 120IPM with the old 400 watt Fanuc 0M motor to over 600IPM with arm ripping accelerations with the P5 1kw. I really really wish I had bought 60 instead of 6!
I don't think the other thread has a link to the video of my table moving using the P5 and the Pixie controller, so here it is:
http://www.skyko.com/videos/SanyoP5.wmv
Old 04-01-2006, 09:40 AM
Thanks for the information. Were do I find some of these amplifiers? I am not really sure what amlifiers are compatiable with these servos. Any suggestions would greatly be appreciated. Thanks
Tim
Old 04-01-2006, 10:46 AM
ger21's Avatar
Also, Rutex has tested the P5's with their drives and said they work very well. But, I don't know of anyone using them.
Old 04-01-2006, 05:24 PM
Yes, I do remember about the rutex drives. Shure would like to see the results of the testing. Was there a problem with the rutex drives and contolling them with Machx?
Tim
Old 04-02-2006, 04:39 PM
ger21's Avatar
Now that you mention it, there might be an issue with the encoder counts being very high, and not being able to get steps fast enough from Mach3. You might have to go with Mach4 and a Grex to drive the Rutex's when it's finished. I have 5 of those motors myself, and that's the route I'll probably take when I get around to using them.
Old 04-02-2006, 04:55 PM
KTP KTP is offline
Gold Member
Both Rutex and the Pixie have built in step multiply, which can help somewhat. Certainly the Grex will be nice when it is fully ready.
What are you planning to do for a motor power supply? The P5's run about 4000rpm off of rectified and filtered AC (such as with an AMC B25A20AC), which is around 155VDC. The new Rutex drives are good to 200 volts DC, right?
Old 04-02-2006, 07:43 PM
I was also planning on using the grex and MachIV. I think the rutex would be a good reasonably priced drive. I am not an enginner or such in the electronic catagory, so relying on expertise from others. There was some questions I believe from this forum, wether or not the rutex would be a good match. I also have some power supply questions such as how to go about building one for these motors and the rutex drives.
I take it that the grex is compatible with the rutex drives, the grex just ouputing the step and direction to the rutex drives.
Tim
Old 04-02-2006, 08:09 PM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
the rutex will work but the board is rated at 100v/20amp continious. and they suggest 80v for optimum performance.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Old 01-11-2012, 10:51 AM
Gold Member
Grifftek is on a distinguished road
PN for Sanyop P5 motors from Surplus Center?
Hi
I have some of these motors that were sold by surplus center years ago. I had all of the motor data but do not currently have access to the PC that it is stored on and was wondering if anyone has the pn's and or the data sheets for these motors,. I have some of the 1000 watt and 400 watt and 300 watt if someone can help me out here it woudl be appreciated.
bill
grifftek @ grifftek . com
Bill Griffin
grifftek@grifftek.com
www.grifftek.com/grifftek
Old 01-11-2012, 02:33 PM
miljnor's Avatar
S.N.A.F.U.
its either in this thread or another like it....just do a search on p5 motors. or On "AL the mans" posts as I think he listed the information....just based off of memory that is....could be totally wrong.
thanks
Michael T.
[IMG] code is Off
