Over voltage on ametek motors?
Can ametek motors be ran at a higher than rated voltage but less current, kind of like steppers?
Ah....nope not much more then 10 percent.....
If you really feed the motor a constant higher than rated voltage, it will overspeed. So you don't want to do that, particularly since you will be in a low. With steppers, as you move you are switching an inductor, so the switching speed is impacted by the voltage di/dt = V/L
I...seee. The motors are 20V 700rpm ametek's.
