| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Hi I have some specs on this Baldor servo motor. I`m wondering if its large enough for my DIY router. I`m using a .2 ballscrew and will gear down the speed of the servo from 5000 to 1000 rpms. MT-2250-ACYCN Max Speed 5000 Torque Stall 50 oz-in Max Voltage 60 Voltage Const. 12.0 Current Peak 18.5 I did visit the Baldor website but the specs on the motor I have does not seem to match the specs on the website. Mine seems to have a lower current peak then any of the motors that match closely in serial number. http://www.baldor.com/products/servo...r/dc_servo.asp |
| Where did the 50 oz-in come from? It does'nt jive with the other specs given. Going by the Baldor site, I suspect it is higher than 50 oz-in. Al.
Hi Al I got the 50 oz-in spec off the nameplate of the motor. I`m wondering if that is 50 oz-in is per amp. Seems to me I`ve seen that relationship listed on other motors. Baldor has tech email ..I`ll run this by the tech. I too didn`t feel the specs seemed right. It has a max current of 18.5. That spec matches Jeff`s motors at homecnc and they are 360 oz-ins. Regards Barry |
Hi all I posted at the yahoo gecko usergroup and got this reply. This info maybe helpful to other members. "The 50oz-in is the continuous stall torque. The motor can run stalled at that torque all day. The current will be 3.42A at this torque. The peak torque is (50/3.42)*18.5 = 270oz-in. Note that you must not exceed 18.5A at any time or you will permanently damage the magnets of the motor. A safe peak torque is probably around 150oz-in (at 10.26A). You can use this torque for your acceleration calculations. This should give you a theoretical peak thrust of (150 *5 * pi) /0.2 = 11780oz = 736lbs. Allowing for friction losses etc, say 500lbs. Maximum safe cutting thrust will be (50 * 5 * pi)/0.2 = 3926oz = 245lbs. Say around 200lbs to allow for friction. Those figures sound pretty good to me. You could probably get away with a lower reduction ratio, say 4:1 or even 3:1. This will probably make the gearing a lot simpler and would of course give you higher feed rates." |
