Yaskawa Minertia motor connections
Good day all,
I have a few Yaskawa Minertia DC servo motors, Part No. UGJMEE-02SJB31 I wish to know what wires are what on the encoder, there are 5 wires and a screen into a 6 pin plug, blue, brown purple,orange and white. Any others specs on these motors also appreciated.
Greg
www.hobbycnc.co.za
There is some info for the motor in this document:
http://www.yaskawa.com/site/dmservo.nsf/link2/TKUR-5ELHNF/$file/KAE-C240-0H.pdf
For the encoder: did you open it? The Minertia I have has wire markings on the PCB.
Hi Lucas,
Thanks for the link, it doesn't have any info on the encoders though. There are no markings on the PCD. There is a capacitor on the board and I would guess that it goes across the power and that would leave A,B and I. Maybe I will just try.
Greg
www.hobbycnc.co.za
Wire connections.
Hi there,
Did you find out which wires is which on the encoder?
Regards
Nic
Hi Nic,
I opened the cover and determined the pin outs, I never did find a datasheet with the pinouts. I haven't used these motors as they were destined for a laser project, I bought a sealed laser tube last year Feb, it arrived in March, smashed to a thousand pieces. I submitted my insurance claim then and what followed can only be described as an exercise of sheer frustration!
Once I had the mobile number of the CEO (he was dimissed two weeks after I got my cheque incidently) my claim was paid within a month, that was four weeks ago. I might restart my project now that the matter is settled but I am still shaking from the experience. (I won't go into details, maar ek is seker jy weet wat ek bedoel!)
Greg
Hi there,
Glad the matter is at least settled
I am trying to determine it myself but I am not very good at it I am afraid. Sat the hole night last night and still not sure what is going where.
I will wait on your reply.
Thanks in advance.
Regards
Nic
Hi Nic,
If your encoder is similar to my own, do this:
Remove the cover and you will find a small capacitor across the power terminals (a small blue blob about 2mm square), mine were blue and brown, brown being positive and blue negative, connect a 5V (regulated) power supply across these and then connect any 2 of the other wires to an oscilliscope, when turning the motor you should see either 2 quadrature signals 90deg. out of phase in which case the third is the index pulse or you will see one quadrature and a single pulse per rev, the single pulse is difficult to see unless you can turn the motor really slowly.
Hope this helps.
Thanks Belli,
Will have a look at it. And report back.
