| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
| I have a couple of Westamp manuals, can you post a Picture? Al.
| Do you just need the hook up for the connectors? as I could type it over, otherwise if you need specific information I could copy a page or two, the schematic is not all that good because parts are conceptual drawing, parts show individual components. I also have the Motorola cross ref for the output transistors if they ever go. It is a service manual for the A651 series, but it looks the same. Al.
| The connections as folows J1 Pin 1 - signal input (auxiliary) Pin 2 - signal input (standard) Pin 3 - Signal input (tach) Pin 4 - Signal common Pin 5 - current sense output Pin 6 & 7 Limit switch overtravel Pin 8 Electronic shut down indication output Pin 9 - Common for pins 6,7 & 8 Pin 10 - Positive 15vdc Bias for external use Pin 11 - common bias Pin 12 - minus 15vdc bias for ext use Connector J2 Used for external programmable current limit Connector J3 Pin 1 - Pos 15vdc supply input Pin 2 - common Pin 3 - neg. 15vdc supply input J4 Right to Left Pin 1 Pos power supply Pin 2 Pos Power supply Pin 4 Neg Power supply Pin 5 Neg Power supply Pin 7 Pos Motor Power Pin 8 pos Motor Power Pin 10 Neg Motor Power Pin 11 Neg Motor Power Any further questions let me know. Al.
#10
| The motor and DC power hook up to J4 The minimal signals for movement is a ±0 to 10vdc signal between J1 pin2 and J1 pin 4 You can use a battery box and potentiometer. The motor tach goes to J1 pin 3 and J1 pin4. You also need a ±15vdc power supply to feed J3 Pin1,2,3 If the motor runs away, swop the tach leads over. I think the board is marked with the pin number on the connectors. Al.
#11
hi i have a trouble! please help me! ""i have "westamp servo amplifier model no.30059" status: 1.turn on power first operater, or reset power => motor can spin ! but second operate => motor can't spin ! 2.front panel display "0000" 3.J4 Pin 1 Pos power supply ---| Pin 2 Pos Power supply | Pin 4 Neg Power supply |--> have power Pin 5 Neg Power supply ---| Pin 7 Pos Motor Power ---| Pin 8 pos Motor Power | Pin 10 Neg Motor Power |--> no power Pin 11 Neg Motor Power ---| 4. motor start capacitance is ok westamp servo amplifier model no.30059 ==>how much ? if can't find "westamp servo amplifier model no.30059",please tell me exchangeable part ok? i english very pool ! """"""" i'm sorry!!but i need your help , thank you my e-mail : hzs8883310@yahoo.com.tw |
#12
| Personally I would not bother trying to repair them, they suffer from 'Component aging', I replace them with A-M-C as they fail, size depends on motor and what DC supply you are using. See my post #10 for trouble shooting. Al.
