Old 02-02-2006, 06:58 PM
Stevie is on a distinguished road
Brushless spindle drive using
Hi guys
Can I use this
http://www.copleycontrols.com/motion...pdf/7225ac.pdf
to spin one of these
http://www.emoteq.com/quantum.htm size is a 2302
to max rpm using something like a +/- 10V signal generator
Thanks for your time
Old 02-02-2006, 08:26 PM
Al_The_Man's Avatar
It does'nt look like it, unless you have a controller that can supply the Amp with two phase sinusoidal control, and the motor is designed for DC brushless commutation signals.
Also you require an encoder that can feedback the commutation to the controller.
Old 02-02-2006, 09:07 PM
There is a encoder on the motor 2000 line with Halls too
Old 02-02-2006, 09:59 PM
Al_The_Man's Avatar
Then you will need a dual sinusoidal type output from the Controller.
Old 02-03-2006, 05:15 AM
I presume 120dgr apart?
Old 02-03-2006, 05:38 AM
Silver Member
mcpltd is on a distinguished road
That seems an expensive option for a spindle drive, have a look at this.
http://www.motioncontrolproducts.com...ds/MCBPlus.pdf
Also this option does not need an encoder, but will accept one if you want to use an encoder.
Old 02-03-2006, 05:46 AM
I already have the amp; I gave $10 for it; the servo I got 2 for $24
So it's a cheap option
Old 02-03-2006, 05:56 AM
Silver Member
ok, good luck getting th controller.
Old 02-03-2006, 08:32 PM
H500 is on a distinguished road
Where did you get it for so cheap?
Old 02-03-2006, 08:57 PM
The Bay of course
I got lucky
[IMG] code is Off
