02-01-2006, 01:22 AM
| Silver Member | | Join Date: Jan 2006 Location: UK Age: 42
Originally Posted by nashyboy Hi everybody,
I am new to CNC machine building and was wondering if anyone can shed some light on controller limitations before I decide on a final system. I would like to know a couple of things...
1) Is there a controller available which will allow me to manually jog or control the servos without programming them (a bit like the manual controls on a commercially available CNC lathe - for example)? So I can choose the axis I want to move and fine tune it through manual jogging or even perhaps manually machine a piece if required. (I have seen a "joystick" controller, but i'd much prefer a "dial" which hopefully can be adjusted for slow and rapid feed).
2) can two steppers be controlled through one channel? Eg. If I want to have two servos controlling one axis? Are there any limitations (Accuracy / torque) on this type of system?
Thanks for taking the time to read this, hopefully someone can help me out! |
Most servo drivers are bumb (need external control) and to have a jog feature, i think you will need to look at one with some controller or positioner built in, and that will require some programing, but not a lot.
Regarding having two steppers or servos, are you talking about a follower application where one axis follwer the other?
If so that is not a problem with most drivers with onboard control. |
