Old 01-21-2006, 09:43 AM
jeep534 is on a distinguished road
yaskawa servo pack question
I have a yaskawa servo pack model SG DB-05ADG where might I find out how to test / make this thing work. I would like to use it to control the motor on the cnc conversion I am currently working on.
Happy Hunting
archie =) =) =)
Old 01-21-2006, 12:09 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Archie,
Yaskawa has downloadable manuals on their website.
www.yaskawa.com
If you have specific questions, ask them here. I should be able to help you, I've worked with these drives quite a bit.
Regards,
Scott
Old 01-21-2006, 05:49 PM
unterhaus is on a distinguished road
Scott, do you need special software to set up these drives? Is it freely downloadable?
Old 01-21-2006, 06:22 PM
MetLHead's Avatar
Gold Member
I use the digital operator, but I found something called SigmaWin Lite on the Yaskawa site. This looks like a windows version of an old DOS program called SVMON that I used to use.
SigmaWin Lite
The servopack uses RS232 for communication, but not in a standard pinout. This means you will have to build a cable to connect the drive to your PC:
PC (9 pin) Drive
2 ----------- 2
3 ----------- 4
5 ----------- 14
Then on the PC side, connect 4 & 6 and 1 & 7 & 8.
Regards,
Scott
[IMG] code is Off
