Old 01-17-2006, 02:44 AM
jim fuchs is on a distinguished road
Smile help a newbee, trying to build a cnc torch table
hi guys , im a junk yard dog, been diging for a long time for parts to make a 4x8 table torch cnc. just snached 3 servos they are alen bradley y-2006-1-h00aa 4500 rpm 8 poles 13volts brake specks 5.64 lbs-in. holding torke
.031amps at 24vdc coil . cont. stall torque 6.1 lbs-in peak torque 17 lb -in
encoder data supply volts 4.75 to 5.25 vdc 450ma dc
first off they say to use a a/b drive part no 1398-dbm-019 can i use something else with them i found 4 new servos . please tell me where i can get a diagram of what it takes to rig the motors to a computor to drive them . im new so be easy on me . the rest will be easy . im a tool maker and fairly good with electrical but i need the basics . jimthanks will these have enuf power .
Old 01-17-2006, 05:46 AM
Karl_T's Avatar
Karl_T is on a distinguished road
If you dig long enough on Allan Bradley's website, you should be able to find the user manual. You need to find if its a brush type DC servo motor. most likely is.
If so, gecko sells a cheap step to servo driver that you can use with a package like Mach3. You've got a small motor here, 24 volt max, (16*17) oz/in. You've lots of RPM, gear the unit down for more torque on your table.
Karl
Old 01-18-2006, 01:45 AM
a/b help please
this is what it says on the a
Y-Series
Y-Series motors, available in either 115V or 230V windings, use high energy neodymium magnets that provide low inertias for fast acceleration
will the geco run this motor . jim
[IMG] code is Off
