Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: I've screwed up.
    Dec 2005
    I've screwed up.
    Hello all,
    This is not the first post I wanted to make. I caught ebay fever and bid on what turns out to be a servo motor, Cleveland Motion Control model BMR4445ACGBOHS0002. It was described as a stepper, but I can now see from the documentation that it is not intended to be a stepper, but a servo only.
    Does anyone have experience with these, such that you could tell me if I can modify it to be a stepper, or should I put it in a closet until I can use a dedicated servo motor?
    Thank you, Tom Perkins
    Mar 2003
    Shelby Twp, MI....USA
    Just sell it again. You might even get more than you paid. No, you can't turn a servo into a stepper.
    Jan 2005
    Toronto, Canada
    Is there any reason why you can't make use of a servo motor? With the proper driver, it can do anything that a stepper can and will even be faster.
    Dec 2005
    Hello H500,
    All my research and circuits experimentation has dealt with steppers, also, it is not merely not the "stepper" motor that it was described to be in the listing, it is also very much more than I need.
    It isn't 200oz/in max, it's 200lb/in max, roughly 2.5kW. It has a 350VDC max back emf at 7krpm. I can use stepped up and rectified house AC current to supply it at about 1/4 of it's rating easily enough, and that's all I need--and if it were in fact a stepper, I'd feel fine with designing and building a drive for it, but I just don't know servos.
    What sites would you recommend to help me homebrew a driver for this beast? I've looked at the UHU site: http://www.uhu-servo.de/ I don't have any kind of feel for servos though.
    Thanks, Tom Perkins
    Dec 2005
    Tom:
    If the motor you received was NOT what was advertised, I would contact the seller IMMEDIATELY, and ask for a FULL refund. HE (the seller) has a responsibility to sell exactly what he listed. If you did NOT receive what you bid on, you have a legitimate claim for refund. EBay will assist you if you do not get satisfaction from the seller.
    Bob C.
    Dec 2005
    Hello Bob,
    I have contacted them, but I just won it today at around noon. I realized the item was not a "stepper" about a half hour after I bid, and to be fair it was also described as a servo, the discrepancy could have clued me. I don't have a response from them yet, but it is early.
    I would have appreciated them not using the world stepper in a description of a servomotor though.
    Yours, TDP
    Dec 2005
    Tom:
    If you just won the bid, perhaps by contacting EBay right away (like NOW). you may be able to withdraw your bid.
    Bob C.
    Dec 2005
    Hello Bob,
    I've already contacted the seller and eBay, I am hoping for a positive reply. Alternatively, I'll relist it--with a more accurate description and with some electrical tests performed--and hopefully move it at a small profit (the most I deserve) or at worst a small loss (I hope that's the worst I deserve).
    Yours, TDP
    Jan 2005
    Toronto, Canada
    The high power and voltage makes it a poor candidate for a home-brewed controller unless you really know what you're doing.
    Most home cnc machines only need 50-200 watts of power. A stepper would be much simpler. Take a look at www.automationdirect.com. A decent motor can be bought for $30-40.
    Gold Member Bloy2004's Avatar
    Oct 2003
    Sturgeon Bay, WI
    I didn't notice if you listed the actual auction... could you provide that so I could view the "ended" auction?
    Dec 2003
    Quote Originally Posted by tdperk
    Are you sure that is the right sizing, I would have expected a larger motor for that power, going by the dimensions shown.
    Dec 2005
    It item number 7575629217
    or URL
    http://cgi.ebay.com/ws/eBayISAPI.dll...3D50%26fvi%3D1
    Here's the URL for the motor sales brochure.
    http://www.cmccontrols.com/downloads...duct_Guide.pdf
    Yours, Tom Perkins
  • Page 1 of 2 12 LastLast
