Old 12-26-2005, 08:35 AM
tphillips is on a distinguished road
Question Looking for info on HEDS-5310 encoder
I have a couple on small servo motors with HEDS-5310 encoders. Instead of the standard 5-pin connector, they are outfitted with a 10 conductor flat cable to a 2x5 .100 connector. I couldn't find anything on the web, anyone know the resolution and pinout?
TIA, Terry
Old 07-22-2006, 08:20 AM
alvarenga is on a distinguished road
Thumbs up Mr
I do have clients that are in need for those micromotors with 5310 encoders.
The portion of the part number refers to the encoder´s resolution and bore
diameter. Sometimes the resolution of the disk is printed directly on the disk itself. If you have any specs or digital pictures of it.
Please send them to me, so i can check and exchange information.
best regards
Alvarenga, Itamar
Old 07-23-2006, 05:17 AM
fkaCarel is on a distinguished road
From an 1985 HP databook.
The 5 in 5310 is the size 28 mm diameter encoders. The 3 in 5310 points to ordering info, emitter plate only(?), 0 is a complete kit. The 1 is 3 channel (+index), 0 is no index. The 0 is mechanical configuration, 0.6 mtr flatcable. It must be followed by an option letter for resolution:
C - 100 CPR
D - 192 CPR
E - 200 CPR
F - 256 CPR
G - 360 CPR
H - 400 CPR
A - 500 CPR
I - 512 CPR
additional CPR-codes (6000-series)
B - 1000 CPR
J - 1024 CPR
After this comes a double digit, coding for shaft size, which I leave out for sunday laziness.
Pinout bottom view:
Edit: I see that all spaces, that would make the following clear are eaten up, so I will add for each pin (PIN)
Vcc PIN 2 PIN 1 Channel A
NC or Ground PIN 4 PIN 3 Ground
Ground PIN 6 PIN 5 NC or Ground ---With bottom view here the Connector Notch
Channel B PIN 8 PIN 7 Vcc
Channel Index PIN 10 PIN 9 Vcc
Note: all the Vcc's and Grounds must be connected, they function as noise suppression.
Carel
Old 09-14-2006, 05:25 AM
eladtsa is on a distinguished road
i need help
hello
i not undestend
if you find dataseet please send me
i need more information
tanks
eladtsa@gmail.com
Old 09-14-2006, 05:26 AM
hello
i not undestend
tanks
eladtsa@gmail.com
Old 10-22-2006, 12:04 PM
i have datasheet
hello
if you neet datasheet about heds 5310
send me mail
bay
TIA, Terry
Old 04-03-2007, 12:46 PM
Gregory Moore is on a distinguished road
HEDS-5310 Encoder
What type of motors are the encoders attached too? What's the price and lead time for the motors/encoders? Would you send a quote?
Regards,
Greg
TIA, Terry[/QUOTE]
Old 04-03-2007, 12:56 PM
hi
Regards,
Greg
TIA, Terry
[/QUOTE]
i have small motor DC 100W
price of encoder 30 $
good day
Old 04-03-2007, 03:29 PM
Hello
Please send datasheet on heds 5310 encoder.
Regards,
Greg
Old 12-06-2007, 02:02 AM
ATGM is on a distinguished road
Scans of HEDS-5000 Series Data Sheet
http://www.telusplanet.net/public/mc..._5000_5310.htm
I couldn't find anything on the internet but was lucky and had the 1984 hard copy. Hope this helps you.
Andrew
  #11   Ban this user!
Old 12-06-2007, 04:56 AM
Thank you Andrew and Carel for the information. One of these days I need to get back on this project....
Terry
[IMG] code is Off
