Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: Aerotech + fanuc
    Sep 2011
    Pribaltic
    Aerotech + fanuc
    HI!
    I connected optional incremental encoder ( 2000 cpr) witht Hall 8 pole outs to Fanuc 20F A06B-0352-B731 .
    I have tuned hall encoder out signal with motor back emf - it is ok,
    I'm trying to control motor by Aerotech BA30-320
    Motor spins cw/ccw, but at low rpm no stability, I can stop rotor by hand!
    Motor can spin about 2000 rpm
    it seems no incremental feedback, only Hall - but incremental encoder connected (Sin, Cos )
    I checked the BA-30 settings several times ( have full manual) , changed JP14 position ( encoder to tachometr ) - motor spins without any changes.
    Can any help with BA-30 ?
    Thank You
    Dec 2003
    I am presently testing some motors on a B30-320 I have used the factory jumper settings,
    except JP14 I am using 2-3.
    Sep 2011
    Pribaltic
    I tried JP14 1-2 and 2-3 - there is no difference
    If to disconnect Sin Cos incremental signal - motor spina without changes (slightly increases the speed). I use velocity mode, with all JP by manual.
    resolution by manual 1000 -1500 cpr., I use 2000 cpr - is this problem ?
    Dec 2003
    I do not connect resolver just hall effect commutation.
    Sep 2011
    Pribaltic
    "I do not connect resolver just hall effect commutation" - and You have good result ?
    Sin Cos feedback signals - is this rectangular pulses are real sinusoidal signal ( like resolver)?
    Why can I stop the engine by hand - and the amplifier is not trying to fight ?
    Thank You!
    Dec 2003
    In the manual I have it is section 2.4.2. and fig 2-6 Current Command Configuration.
    The one you refer to is the Velocity command config?
    I do not have the encoder hooked up, just a battery box. I have it on the bench right now setting up some CUI BLDC encoders.
    In the current mode the POTs are set to INPUT CW and Gain fully CCW
    See 2.5.1.
    Sep 2011
    Pribaltic
    I use velocity mode 3.3.1 by my manual - please check is this right?
    Attached manual
    Attached Files Attached Files
    Dec 2003
    I use the next 3-3-2 works fine.
    Are you using a battery box?
    Sep 2011
    Pribaltic
    What is " battery box?"
    Dec 2003
    A box using two 9vdc battery's and a pot for simulating the ±10vdc analogue command.
    Sep 2011
    Pribaltic
    O, yes two "crone" bat. for +- 10 v
    I trying " current control" - motor spins , but I can stop rotor by hand
    Where the error - I do not understand
    Dec 2003
    Sure the drive is OK?
    Is it used?
    Disconnect power Short the motor phases out and see how hard it is to turn.
  • Page 1 of 2 12 LastLast
    1. Aerotech Rotary Axis
      By Fish4Fun in forum DIY CNC Router Table Machines
      Last Post: 11-21-2011, 09:05 AM
    2. Need Help!- Aerotech amps and servo
      By HONDAPETE in forum Servo Motors and Drives
      Last Post: 01-05-2010, 04:50 AM
    3. Anyone Have Aerotech U600 experience?
      By toolnuts in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 11-07-2009, 10:50 PM
    4. Aerotech Unidex 11 Software
      By davidponte in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-02-2005, 12:59 PM
    5. aerotech XI program
      Last Post: 02-19-2005, 11:56 PM
