| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
| Hello J need i datasheet for this servomotor: model: E-586 SA 0586-24-024 serial nr: 06668 This servo is very old but is's still efficiency. J have tree that's motors and J want it to use to my M.A. thesis. Theme DC servo driven on 80c517 processor. So, therefore J need parameters fot this motor to, so that could to begin. |
| What I have cont. stall torque 29 oz-in pk torque 240 oz-in Max terminal voltage 60 max rpm 6000 inertia .0052 0z-in-sec^ tach 14v/1000rpm armature ind. 3mH Al.
| Can you send for my pdf form this parameters? chomikaaa@poczta.onet.pl J find out this one: E586 cont. stall torque 0.22Nm current 3.7A max rpm 6000 Spannumgskonst. Ke [V/(1000*1/min)] 5.85 Drehmomentkonst Kt [Nm/A] 0.056 Entmagnetisieurungsstr [A] 24 Tachogenerator Rl=5kohm Spannumgskonst. Ke [V/(1000*1/min)] 14 Thanks for all Last edited by chomik; 11-15-2005 at 09:04 AM. |
| Hi everyone, I need some help for my final year project to retrofit the Hercus V300 mill. I'm totally new to this. The mill machine uses the Electrocraft E-586-SA (0586-24-024) axis motors. Anyone have the datasheet for this motor? Is this a normal DC motor or Servo DC motor? What requirement does the motor drives need to drive this motor? Hope that someone can help me with this. Cheers! |
| The only 0586 I have shows: Cont Stall Torque 29 oz-in peak 240 oz-in max voltage 60vdc max rpm 6000 Kt 9.6 oz-in/amp Ke 7.1 V/krpm 7.1 This is a DC P.M. servo motor. http://electronicdesign.com/Articles...leID=7635&pg=1 Al.
| Drive and power supply, I usually aim for 110% minimum. Advanced Motion Controls have some good engineering notes also. Al.
