Old 02-01-2012, 01:19 PM
CalG is on a distinguished road
Yaskawa USAREM encoder or amplifier options?
Hello
I've been poking around with a Yaskawa USA REM servo motor. which should be matched with a CACR PR07 Amplifier . Those seem to be quite rare.
This motor holds a pair of 1500 counts per rev encoders. One is TTL, and the other 12v. Both square wave.
Can anyone advise a scheme or suggest an alternate (available) amplifier that will work with this combination.
The MPA servo amplifier I have only has settings for Encoders with multiples of 512 counts per rev.
An Emerson FX drive is incompatible in a number of ways. ;-)
Comments or advice? I don't know much about servo motor and amplifier compatibility. Perhaps an encoder change is my best option.
TIA
Cal
Old 02-01-2012, 07:50 PM
mike_Kilroy is on a distinguished road
can u list motor spec sheet? w/more info there will be alternatives. we run most other mfgr motors with our drives all the time....
Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit
Old 02-01-2012, 11:21 PM
From the literature
Mike Thanks for the response.
USAREM 07A E2NX
At 200Volts
Rated out put 700W
Rated Torque 2.23 N-m
Cont Max T 2.67 N-m
Peak T 6.67 N-m
Rated Current 5.7A
Rated Speed 3000rpm 4500 max
Torque Constant 0.46 N-m/A
MoI kg-M2 X 10^? 372
Power Rate 13.3 kW/s
Inertia Time Constant 2.5ms
Inductance Time Constant 10ms
Info about encoders (optical) from the Servopack amplifier specs in the same document next page. (assume the in to the Amp is the out from the encoders)
Input Sign and pulse, two phase
90deg diff.(A+B) 5V TTL line driver
or +12V open collector
Pulse frequency 0-200kpps
Aux Reference pulse 2 phase 90deg diff (A+B)
pulse form +12V open collector
pulse freq 0-100kpps 4 multiplier internal processing
Control signal clear and inhibit
pulse form 5V TTL or +12V open collector
PG Pulse output
Pulse form Phase A+B Line driver
Phase C open collector
freq dividing ratio 1/1, 1/2,1/3,1/4,1/5,1/6,1/10,/12,1
/15,1/20,1/30,2/3,2/5 (HEX rotary switch)
I hope this formats the way it was typed.
Thanks for your attention!
Cal
PG pulse Output
Old 02-01-2012, 11:27 PM
Al_The_Man's Avatar
What kind of control are you intending to use with the drives?
This may be the deciding factor as to who's drives you can use, for e.g. if using Mach, the Granite drives should work?
Old 02-01-2012, 11:53 PM
Well, I'm a step and direction kind of guy with EMC2 ( LinuxCNC now I hear)
Ill look at those GD amplifiers
Old 02-02-2012, 05:29 AM
so summarizing what kind of amp you need, you need one rated:
200v or higher
6amp continuous output
TTL encoder input
pulse/dir output
AC or brush type? Pick one - those specs do not tell if this is a brush motor or not. (2 wires or 3 for running it) or (brushe caps sticking out the sides?)
I think AMC (a-m-c.com) has drives that can meet these specs too. Just saw forum on here with relatively new drive called rutex that may do, and I know Kollmorgen (.com) does also.
Old 02-02-2012, 09:37 AM
Sorry, I assume too much
Mike,
I am sorry to omit the important bit regarding motor type. You know how it goes, when a topic is in the front of one's own mind, one assumes everybody else is thinking the same way:-) In my defense, that little detail is NOT included in the specifications listing..;-) But no excuses..
The Yaskawa USAREM is a 3ph brushless AC device. No Brushes!
Your suggestions regarding amplifier characteristics is right on. I had hoped that there might be a contemporary device that offered the flexibilty to match with this motors encoders. As mentioned, the AMC amplifier does not allow 1500ppr encoder input. (Though perhaps 512X3 would be accepted. Close!)
The Granite Devices units look promising The peak voltage limit of the Granite Devices (180V) may not be a show stopper. Most of the service application will be at rotational speeds well below peak. I need to take another look at the combination. Along with the motor performance curves.
I took too much time perusing e-bay, and it seems that the Yaskawa CACR-SR series drives are quite common. At first pass, they are described as backwards compatible. I will compare the wiring for those units a bit more closely.
Wouldn't it be nice if motors and drives were somehow in-seperable.
Ah, but then they would be called "package drives" ,
Cheers
Old 02-02-2012, 09:53 AM
Al_The_Man's Avatar
AFAIK all AMC drives are all non-intelligent drives and are intended to be used with controllers that close the PID loop rather than the drive, which includes EMC if used with the proper card, this uses the drive in the torque mode, AMC only use the encoder when used in tach feedback mode, but can take 1500p/rev encoders.
Old 02-02-2012, 10:44 AM
It was late. AMC <-> MPA
Sorry to make reference to the AMC drive which I have not had any exposure. I am opening the AMC pages now, (though the navigation to brushless drives appears to be a bit balky.)
With a through reading, the MPA amplifier offers input or an assortment of encoder counts.
including
250, 360, 400, 500, 720, 1000, 1024, 2000, and 4096 ppr
Just no 1500 ppr ...my luck...
Help me understand a detail . The term "Simulated Encoder Signals" is the header for this section of the operations manual.
the text reads:
"For external counting or position control, 9-pin D type connector that has TTL compimentary outputs is provided. This Simulates quadrature encoder channel A and B signals. A differential mark signal is also available"
Please tell me if you can, just what this paragraph describes. The "simulation" ande "output" throws me off.
This amplifier also serves for motor pole counts of 4,6 8 and brush type. (The later without resolver feed back requirement) I have not determined the Yaskawa motor pole count. I best go spin it around once while connected to the o-scope.
Old 02-02-2012, 11:35 AM
Advancing the possibilities
Can a DC brushless drive be used to control an originally AC Brushless design motor with only the penalty of slightly decreased performance?
i.e. V/rpm or Torque/ amp.
TIA
CalG
Old 02-02-2012, 11:47 AM
Al_The_Man's Avatar
The 'simulated encoder output' generally refers to such as AC sinusoidal motors fitted with for example a resolver, the drive will extrapolate and produce a pseudo encoder signal of various resolutions and of 5v Differential in nature for use by the CNC controller.
AC sinusoidal can generally be used with a BLDC drive, there should be no noticeable performance although some report the sinusoidal control being smoother, especially at lower rpm, but I have used them in BLDC mode with no noticeable difference.
With BLDC two stator windings are energized at any given time, with the AC all 3 windings are powered simultaneously.
Evidently in some manufacturers products, the shape of the rotor magnets can be different with AC sinusoidal having domed tops to the magnet, rather than following the natural dia. of the rotor?
I haven't had the opportunity to confirm this, however.
  #12   Ban this user!
Old 02-02-2012, 12:39 PM
mactec54 is on a distinguished road
CalG
Do you have the PDF for this motor Drive, this is about 20 to 30 years old, still a good motor if you can get the right drive for it, I have the PDF if you need it
Mactec54
[IMG] code is Off
Broken BridgePort Encoder, Need new encoder or ServoMotor w/Encoder TNBG_LTD Want To Buy...Need help! 0 03-22-2011 09:20 PM
Need Help!- Initializing servo amplifier Yaskawa CACR-IR30 ing.vic Servo Motors and Drives 1 12-10-2010 11:20 AM
Yaskawa ac servo encoder problem Grubma Servo Motors and Drives 2 08-16-2009 12:24 AM
Yaskawa USASEM-08TF22-A encoder schematic diagram tayfunk Servo Motors and Drives 0 03-03-2009 07:37 AM
Yaskawa Encoder-DC Servo Motor trouble nlh Servo Motors and Drives 2 11-28-2006 08:58 AM
