| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
#13
It is a series of "photo copies" of some original manuscript. From the Yaskawa pages document reference TSE-S800. A "generic" outline of the Series R servo drives (with specs) . Is the document you have different? The motor does appear to be a good one, and it is fitted with a gear reducer that makes it just right for this process motion application. If budget were no consideration, I'm sure a solution would come rapidly. Knowledge has a value as well. |
#14
| CalG I do have some of the old manuals, But the PDF you have is just a copy of what is in the manual everything is there that you need for that Motor Drive information Is your PDF the TSE-S800 2.8C
__________________ Mactec54 |
#15
| calg, some more info fwiw. a motor designed for trapazoidal commutation (aka BLDC) run on a sinusoidal commutated drive can have a system performance reduction upto about 20%. a motor designed for sinusoidal commutation (aka ac brushless) run on a trapazoidal commutated drive can have a system performance reduction upto about 20%. ratings such as nm/amp and v/krpm have a difference factor of iirc about 1.6x between the two. the derate is due to extra heat in the motor due to mismatched current vs motor bemf waveform: a trap designed bldc motor has a trapazoidal shaped bemf while an ac servo has a sine shaped bemf waveform. for you, mix and matching will probably be transparent as AL attests to since who is going to realize 10% less rating? Hard for someone not familiar with it to quantify. Al, fyi, sine bemf vs trap bemf has more to do with winding and lamination shape than magnet shape; ie., dome shaped magnets in themself do not make sine bemf: most of the magnets I see today on ac motors are still square. calg, want to know how many "poles" your motor is short 2 of the motor leads and rotate it thru 1 mechanical rev: count the humps. humps= no of poles. this is top secret info so don;t share with others - share and I loose job security -people will know everything I know and I wont be needed anymore ![]() calg, search ebay for CE06 kollmorgen drive; it will run your motor & encoder fine and also give u the simulated encoder output to feed on to a mach3/emc cnc controller. if you dont find what you want feel free to pm me for quote on used or new one.
__________________ Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit |
#16
With the gear reducer hanging off the front of this motor, Spinning by hand is a real chore! ;-) but perhaps acedemic at this moment. I have just spent over an hour looking at the documents for the CACR-SR seris drives, and I must say it's impossible to put numbers to application. In example, there is an amplifier described as CACR-SR15BC1KSY392 The Yaskawa literature on the -SR amplifiers has no reference to BCKSY designations. An inaccurate description? Some other literature? frustration... I'll take a look for the Kolmorgen Drive... Thanks CalG Last edited by CalG; 02-02-2012 at 08:25 PM. |
#17
Seo perhaps? Well, Ebay comes through... http://www.ebay.com/itm/Kollmorgen-S...item1c2044296c It seems costly for a piece with damage... |
#19
Set it up in the lathe output shaft chucked up, turn the spindle slowly, observe the response on the o-scope. I did that not long ago to take a look at the encoders. I suppose I should have checked the motor poles at the same time ;-) |
| Broken BridgePort Encoder, Need new encoder or ServoMotor w/Encoder | TNBG_LTD | Want To Buy...Need help! | 0 | 03-22-2011 09:20 PM |
| Need Help!- Initializing servo amplifier Yaskawa CACR-IR30 | ing.vic | Servo Motors and Drives | 1 | 12-10-2010 11:20 AM |
| Yaskawa ac servo encoder problem | Grubma | Servo Motors and Drives | 2 | 08-16-2009 12:24 AM |
| Yaskawa USASEM-08TF22-A encoder schematic diagram | tayfunk | Servo Motors and Drives | 0 | 03-03-2009 07:37 AM |
| Yaskawa Encoder-DC Servo Motor trouble | nlh | Servo Motors and Drives | 2 | 11-28-2006 08:58 AM |
