Old 01-29-2012, 01:04 PM
jsokolowski is on a distinguished road
Spindle motor wiring
I purchased a spindle motor and VFD. The spindle has no manual so I am not sure how to wire it. It is a 2.2KW 3 phase motor with four terminals numbered 1, 2, 3, 4. I am assuming one of these is a ground but don't know how to identify it. Any suggestions?
Thanks.
John
Old 01-29-2012, 02:17 PM
Al_The_Man's Avatar
Well operating a vague area!
But the one that is ground can be confirmed by continuity (zero ohms) to motor frame, the other three should read isolated from frame and read exactly the same resistance between any two.
Old 01-29-2012, 04:00 PM
Thanks Al. What I have is a short among three of the terminals so I assume these are the motor windings. There is an open between the fourth terminal and any of the other three pins. I am assuming this is ground. I will check it against the motor case.
I did power the unit up and had no fault lights but the motor would only turn at a very low speed. My VFD display was only showing 6.6 HZ with the rheostat at max. There was also a clicking sound from the motor.
Old 01-29-2012, 05:20 PM
Al_The_Man's Avatar
Do you have info or pic of the motor name plate?
Old 01-29-2012, 07:00 PM
Al,
Motor nameplate is GDZ-80-2.2b. Rated at 220V 400HZ 3 phase. That's all it has.
John
Old 01-29-2012, 08:13 PM
I got the motor to behave properly. As I suspected the terminal that was open to the others was the ground. The reason my spindle did not operate properly on initial trial was the VFD settings. I had to adjust them to my spindle characteristics. Works just fine now except rotation appears the wrong way. Will have to look for another setting for it or maybe swap motor wires.
John
Old 01-29-2012, 08:36 PM
paul3112 is on a distinguished road
vfd spindle
any name /model of the vfd?
Old 01-29-2012, 08:45 PM
might help
Appendix A - Mach 3 PWM V1.1.pdf
HY Series Inverter 20100627.pdf
Old 01-30-2012, 08:16 AM
Thanks for the documents. It turns out that the fourth terminal on my spindle is not connected at all so there is no ground connection. Not sure if I can run the ground wire to the motor casing itself.
John
Old 01-30-2012, 09:46 AM
Al_The_Man's Avatar
That must be one of those Chinese spindles that are supplied with a ground terminal which is not connected to the frame, end users usually end up putting it on themselves and running a ground conductor to it, it is required by code and to prevent noise issues.
  #11   Ban this user!
Old 01-30-2012, 04:50 PM
noise
Ah yes the saga of the RF. Need to get some ferrite slugs and EMI filters.
< EMI/RFI Filter & Power Entry Modules - SAE Power > is an example
Probs I had:
Noist to limit switches
Noise to E stop
Noise in the lan and wifi
get your head around sheilding and earthing. they are two diff things. I am not up to speed with US codes.
Paul
  #12   Ban this user!
Old 01-30-2012, 05:51 PM
cnt cnt is offline
cnt is on a distinguished road
I am bit concerned you have no proper ground terminal inside the motor connection box.
Do you have an “E” mark beside a screw inside the connection box? If so it should be the ground terminal. Check the continuity from the screw to the motor body for verification of grounding.
[IMG] code is Off
Problem- Spindle motor wiring on x3 imprez55 Benchtop Machines 2 10-13-2009 03:59 PM
Need Help!- Spindle Motor Wiring lavrgs Tree 0 08-05-2009 01:46 PM
Spindle motor wiring rich_cree Taig Mills & Lathes 3 02-02-2009 09:58 AM
Need help wiring 230V AC spindle motor Heavy D Knee Vertical Mills 4 05-06-2006 11:24 PM
Boss spindle motor wiring questions moto21 Bridgeport and Hardinge Mills 11 03-29-2006 10:13 PM
