Old 01-29-2012, 09:24 AM
ABT ABT is offline
ABT is on a distinguished road
NEC ADU .. F.X servo drive interface
Is there somebody who could help me on information (documentation etc) of these NEC (Sanyo Denki) ADU servo drives?
I''m busy replacing the Seicos 3M control of a Hitachi Seiki VM-40III (anybody interested in parts?) with a Siemens 802 cnc control.
Because only the seicos part of the control had problems I'm up to use as much original parts as possible.
The spindle drive for instance is a Mitshubishi Freqrol FR-SF type and all the manuals are downloadable of the internet.
The problem are the 3 servo drivers, brand: NEC, type: ADU20F1X;
I can't find any information for these drives to interface them.
The only documentation supplied with the machine is the electric scheme, I've scanned the servo drive connection.
There is only one cable connected with the cnc (CD2 --> CP11). The pin arrangment of this cable is also scanned.
If there is somebody who could explain how this drive is controlled (analog or digital) and how the drive settings are changed, I would be very happy because otherwise I have to replace the drives for new drives.
Kind regards,
Aad Boers
The Netherlands
ID:	151402   Click image for larger version
ID:	151403   Click image for larger version
Old 02-01-2012, 04:11 AM
ABT ABT is offline
Nobody?
Old 03-31-2012, 08:36 AM
afterburner27 is on a distinguished road
Kind regards,
Aad Boers
The Netherlands
Ik zit met hetzelfde probleem Aad,
Maar jij hebt nog de schema's erbij..ik heb zelfs de schema's niet.
Probleem bij mij NEC ADU05FX1 drive als 4e as sturing,
Eerst een instant over current..nu heeft de as een paar weken gedraaid, en dan een effective current over...
Heb jij iets in die boeken staan over deze meldingen..eventueel schem's waar ik mee uit de voeten kan...of parameters die veranderd kunnen worden???
Mvgr Nico
Tags
adu20f1x, hitachi seiki, nec, sanyo denki
[IMG] code is Off
Need Help!- Mitsubishi MR-J2S drive conversion/interface EnvisionElec Servo Motors and Drives 1 03-21-2011 11:13 PM
Need Help!- Project! Haas Vector Drive replacement, MOCON board / Brushless Servo Amp interface marvinmfg Haas Mills 12 07-10-2010 09:04 PM
Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. kreutz Stepper Motors and Drives 3 07-03-2008 06:57 PM
Kerney Trecker Tape Drive Interface chammerbeck Machine Problems, Solutions , Wireless DNC, serial port 6 04-21-2008 03:02 PM
Computer to drive interface CRFultz General Electronics Discussion 2 04-25-2005 10:45 AM
