| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
When looking at steppers they are NEMA23 34 etc.When looking for servos and gearheads there is many with 60 size frame 90etc.OK so I assume there is 2 different mount size flanges.NEMA and metric.Is there such a thing as an adapter plate?Some of the gearhead manufactures claim any servo can be mounted to their gearhead with their clamping hub. The question would be,I have size 60 gearhead.can it be adapted to NEMA23? Thanks Larry
__________________ L GALILEO THE EPOXY SURFACE PLATE IS FLAT |
| there are lots more than even those 2 standards. yep, nema and the metric is called IEC sizes. I have experience with thomson micron & stober gearheads: both will mount to ANY motor - within reason. there are limits to min and max shaft diam and then of course flange size must be adaptable. these and others like alpha typically just ask for the exact motor part no customer plans to use with a given bo and then provides that adapter plate for typically no additional cost. if one gets hold of a used box then of course they will have to pay for the adapter plate and coupling piece(s). any distributor for your brand gearbox should be able to get you a part no and price for your exact motor if you ask them.
__________________ Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit |
| Thanks mike. Us guys with little or no money should be careful when buying from E-Bay to get a match.I would hazard a guess an adapter would cost more than I paid for the units on E-Bay.I E-mailed Wittenstein to ask if my servo would mount to their Alpha series 60 and they did not seem to understand.I assume they are not interested in any help to the small guys.May have to re think and return to belt drive Larry
| Need Help!- Servo Gearhead with Encoder Question | Gene-Yo | Servo Motors and Drives | 4 | 01-01-2012 03:51 PM |
| question for gearhead dan | patchwork | Shopmaster/Shoptask | 0 | 12-14-2010 07:35 PM |
| Need Help!- diy gearhead | eloid | DIY-CNC Router Table Machines | 4 | 03-13-2008 06:19 AM |
| can i use this gearhead ? | max_imum2000 | Linear and Rotary Motion | 3 | 01-27-2007 08:02 PM |
| Refitting servo mounting flange? | Tig | Mechanical Calculations/Engineering Design | 2 | 01-06-2007 01:32 AM |
