| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
| My servo motors are rated at 85vdc 7amps,and are the motors that came with on the mill when I bought it,after putting power to the machine I took a reading at the motor input and it read 100vdc. Should I be making sure that it only puts out 85vdc max or should it be less,I will be using viper 200 drives and mach3. Any help would be great. Thanks Mike |
| With PWM drives you can control the voltage mean level in order that the motor does not exceed its maximum rpm. 100v on a 85v motor will do no harm, per-se, only if it was continuous causing overspeeding. Al.
| Newbie- Power supply for my stepper motors | tmcp | Stepper Motors and Drives | 1 | 01-20-2009 10:07 PM |
| Is it mach 3, power supply or motors? | tauscnc | Mach Mill | 4 | 12-06-2008 08:17 AM |
| Question about power supply for the motors | SteveC68 | CNC Wire Foam Cutter Machines | 7 | 03-28-2008 08:45 PM |
| Help with Power supply or motors ? | rodzilla | Stepper Motors and Drives | 5 | 11-29-2007 09:58 AM |
| Power supply for 3 xylotex motors | PEU | General Electronics Discussion | 13 | 06-18-2005 01:07 PM |
