| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Hello All, I am piecing a new gantry wood router together from my latest ebay scavenging. In doing so, it has got me leaning in the direction of eventually having a bit of variance in the chosen servos on the 3 axis (in size and voltage). Since my previous machines have had identical motors on x,y,z so it feels a little odd in deviating from that, but the more I think about it, the duty, or about of work doled out by each axis, does seem to be spread out a bit unevenly. Looking at the amount of force required to move each axis and the weight each is holding/pushing, here is my very unscientific/guess breakdown of the percentage of power required to move each axis: X) 60% (needs to push/pull weight of Y and Z assemblies and gantry itself) Y) 25% (needs to push/pull weight of Z assembly) Z) 15 % (needs to push into material assisted by gravity/lift its own weight) The above figures are a bit exaggerated, but illustrate my question- Does anyone else run mismatched servo sizes on their machines? I know it would be convenient to have them all be identical, but due to the recycling/scrap aspect of this machine, that might not happen- at least not for the first incarnation. Thanks, Mike
__________________ Expensive tools can be cheaper than professional therapy |
| ??It is often rare to have all identical motor sizes on a machine, each have usually very different loads and acceleration rates? Sometimes voltage variation between motors can require some changes especially when wanting to use a common supply, if supplies are separate, then it does not really matter? Al.
| Hey Al, That's good it is more common than I assumed- My Techno Isel had the exact same motor on all 3 axes, as well as the old mill I put together years ago (just because I happened to have 3 that matched). When I see "CNC XYZ motor kits", they (nearly) always advertise 3 identical motors. That is why I was stuck in that mindset. Breaking free from that is what felt odd at first. Also, yes- I plan on having 2 power supplies. I have a 30v power supply that I am going to use for the Z driver and z brake. I also plan on a 70v power supply for the X axis (has a 60v MCG motor). Follow up question- do you think that if my Y axis motor is rated for 38.2v that it would be streching it too far to run it from a 70v supply? I see often a rule of thumb that says to use a supply that is rated at 150% the max voltage of your servo's voltage rating. I suppose I could just try it and see if it works- then if not, just get a bigger servo. Thanks for the input, I appreciate it. -Mike
| 70v for a 40v motor may be on the high side, it would mean your drive is going to operate in the 60% range to limit the rpm. see Power-Supply Considerations For Servo Amplifiers If these are linear supplies with toroidal transformers, you could easily remove turns to suit. Al.
| Excellent link- I will read and reread that one in detail tonight. I haven't bought the 70v supply yet, but the one I was eying is a toroid. Thanks again- hopefully I'll have some more details to throw in a new machine build thread sometime soon ![]() Thanks, Mike
__________________ Expensive tools can be cheaper than professional therapy Last edited by mikkojay; 01-09-2012 at 03:18 PM. Reason: kant spel |
Easy to mod, also if you need a small aux supply, just add an overwind. Al.
| 3 axis CNC Servo Controller with servo motors--$700 | CuttersCov | EBAY ADS | 0 | 07-23-2009 11:49 AM |
| Just IN- Provide controllers,drives,servo motors,stepper motors,electronic parts from China | Ling | Product Announcements & Manufacturer News | 2 | 07-12-2009 04:10 AM |
| Galil Motion Controller, with NEMA 23 Servo Motors, Servo Drive, Encoders, Etc. | qualitymachine | EBAY ADS | 0 | 06-01-2009 02:26 PM |
| Pluto Servo - Motors won't servo correctly???? | TZak | LinuxCNC (formerly EMC2) | 2 | 01-10-2008 02:34 PM |
| Need servo motors for desktop CNC milling machine | PKaren | Servo Motors and Drives | 3 | 12-19-2006 06:01 AM |
