Old 01-01-2012, 05:43 AM
mcv300 is on a distinguished road
Inertia & reduction question
If a motor has inertia of 0.2 kgcm^2 paired with a reduction gearbox of 1:10 with 0.1 kgcm^2 inertia
How much is the total inertia now ?
a) 30 kgcm^2
b) 20.1 kgcm^2
Thank you
Old 01-01-2012, 12:04 PM
mike_Kilroy is on a distinguished road
neither....
c) 0.3kgcm2
gearbox inertias are given at the motor shaft side, so the motor sees .1.
the motor is .2, so the total is .3
missing is the LOAD inertia: IT goes thru the gearbox and gets reduced by the square of the ratio, or reduced by 100 in your case.
Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit
Old 01-01-2012, 08:09 PM
Thank you Mike,
very valuable information for me
Old 01-02-2012, 06:34 AM
load inertia reflected to the motor is most important also.... consider playing with free Motioneering to see how all inertias interact for different type mechanical systems:
MOTIONEERING® | Kollmorgen
[IMG] code is Off
low or medium inertia for router? Boltz Servo Motors and Drives 8 03-25-2011 05:41 AM
Question about gear reduction on small belt machine rlrhett DIY-CNC Router Table Machines 1 04-10-2008 06:12 PM
Help, Inertia or Torque gdb Stepper Motors and Drives 3 04-30-2007 03:30 PM
load inertia measurement postvmvs Mechanical Calculations/Engineering Design 1 04-05-2007 08:16 PM
inertia example, love some feedback veteq Servo Motors and Drives 15 08-08-2006 06:30 PM
