| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
| I am going to be retrofitting a series 2 bridgeport mill. I found these ametek motors on a surplus site. they want $75 each. They have the smaller shaft on one end for the encoder. Does anyone have an idea what the torque ratings are for these. I would like to put 48v dc to them. Are the encoders expensive to fit to them? I am trying to save money where I can on the retrofit. But the motors are one of the most important things from what I guess. Here is what the ad states: AMETEK 38VDC 900 RPM MOTOR 900 RPM AMETEK, #965922-101. Permanent magnet DC motor rated 38 VDC nominal. Reversible, ball bearing. Max. rated rpm is 1300 max. Armature current before permanent demagnetization is 12 amps. Torque constant is 50 oz-in per amp. Terminal resistance 20 ohms +-20%. Voltage constant is 37 VDC per 1000 rpm. When tested on 38 VDC, we recorded the following data: No-load spedd 1100 rpm @ 0.260 amp. With a 100 oz-in load the shaft speed was 900 rpm @ 2.3 amps. When tested as a generator at 1000 rpm, the output was 5.8 amps @ 12 VDC. Shaft: 5/8" dia. X 1-5/16" long. The opposite end of the shaft has a turned down diameter and a flat mounting area with two sets of tapped holes. This was probably originally intended for an encoder or tachometer mounting. This shaft has an outside dia. of 3/16" and is approx. 3/8" long. We do not have the encoders whtat were mounted on this motor, but suitable encoders are probably available from encoder suppliers if required. The motor has five #10x32 tpi tapped mounting holes on the shaft end of the motor body. Electrical connections are via 3-1/2" long flexible wires. Dimensions: 4" dia. X 4-1/2" long (excluding shafts). Thanks for the help. Jason |
| I can't answer your question. but thought of a older but similar thread by balsaman that used the ametek motors. http://cnczone.com/forums/showthread.php?t=7180 |
| One more question about these motors. Why would they have 3 wires for the power I have seen these before but most of the ametek motors I see used as a servo have a Blk/Red wires. These look to have Blk/Red/White wires. Jason |
