| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
I'm trying to get a Fanuc AC servo running using EMC2, the bldc component for EMC2, and an AMC brushless servo drive. The basic idea is that EMC2 takes the C1,C2,C4 and C8 commutation signals from the Fanuc encoder and outputs hall signals to the AMC drive. It can also take incremental encoder signals (but that's still down the road). The AMC drive takes +/-10V analog input, so I've built a pwm to analog circuit so EMC2 can give the drive an input signal. This sort of works and I've made a motor spin. However I currently only have it spinning in one direction whether I give it a positive or negative analog input voltage. So that is my question: Do I need to feed a positive voltage into the + input on the AMC drive for rotation in one direction and a negative voltage into the - input on the AMC drive for rotation in the other direction? I ask because I can make the motor rotate the other way by putting a positive voltage into the - input on the drive, but that doesn't make sense to me... Simulating the input circuit in the AMC drive, I'd think I'd need positive and negative signals on their respective inputs to get reversing motor rotation.
__________________ CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html |
| The AMC has +ref and -ref input, it just need an alternate or reverse polarity between these two to run in either direction? The correct commutation must exist of course. Al.
| I'm leaving one of the inputs at ground and driving the other one with a voltage. So if I'm trying to go forward, I put up to +10V on the + ref input and ground on the - ref. If I want to go backwards, I leave + ref input at ground and put up to -10V on the - ref input. Is that how it's supposed to work?
| This is the drive I'm using: http://www.a-m-c.com/download/datasheet/bx15a20.pdf The manual says: differential reference input (+/- 10V operating range)
| It actually takes a differential signal but it will work single ended, IOW + on +ref and gnd on - ref, reverse is -on the +ref and + on the -ref. I usually test separately first with a battery box. 2 9v batteries in series and a 5k or 10k pot across the outer 18v ends, the series point is common and the slider is ±9vdc. With an normal applied signal, the gnd stays on -ref and the +ref goes pos or neg WRT gnd. Al.
| Thanks Al. That clears it up for me. So I'm currently doing it wrong, but the software portion of my setup is working correctly... I'll have to rearrange my circuit a bit.
| Need Help!- Can a AC Analog Servo drive be in MACH-3 control? | gurukrupaelec | Mach Software (ArtSoft software) | 8 | 06-12-2010 05:59 AM |
| Need Help!- servo drive position control by analog 0-10Vdc or 4-20Ma | rai | Servo Motors and Drives | 3 | 01-09-2010 10:11 AM |
| brushed servo drive with PWM & direction input | visky | Open Source Controller Boards | 7 | 06-17-2009 01:14 PM |
| How to drive Analog Servo Input +/- 10V | gurvy | General Electronics Discussion | 1 | 05-30-2007 11:31 PM |
| want to built servo drive(analog and digital) | grebator | Servo Motors and Drives | 0 | 04-03-2007 10:29 AM |
