Old 12-08-2011, 09:01 AM
will gilmore is on a distinguished road
pwm vs step/dir
I'm starting on a mill retrofit. I'm hoping to reuse the servos. I've used Gecko steppers on a earlier lathe project and I'm comfortable with how the controller / driver / motor work with step pulses using steppers or servos.
For this new retro I've been considering EMC2 and that led me to Pico (Motion Control Interfaces) who offers PWM servo drives. Is this better / worse / older / newer technology?
Thanks.
--Will
Old 12-08-2011, 10:39 AM
samco is on a distinguished road
pwm input drives are similar to +/-10v drives.. The pwm is signal is proportional to velocity, current or voltage going to the servo. This depends on the drive. There are many upsides to using this style of drive system with emc. This is a true closed loop setup. Emc knows the actual position of the machine at all times.
-home once. As long as emc is still running - it knows where it is.
-estop without loosing position.
-move the machine around manually and it will know its position.
-following error is known. mine is .00017" at the moment http://www.electronicsam.com/images/...ing/tuning.png
-I can set the amount of following error before it trips an estop.
-home to encoder index.
sam
Old 12-09-2011, 09:11 AM
are there upsides to step/dir drives?
Old 12-09-2011, 09:12 AM
easier?
sam
Old 12-09-2011, 09:16 AM
ok fair enough. Assuming I'm willing to spend the time learning and configuring, will PWM give better results?
Old 12-09-2011, 10:34 AM
neilw20's Avatar
neilw20 is on a distinguished road
One of the things with PWM is PWM distortion.
You need to use a high speed opto in the MB region so that the on rise time and fall times are identical, for practical purposes.
I use accurate PWM at the VFD generated by step/dir signals.
My step signal drives a monostable, that gives a very accurate controlled pulse width. The faster you hit it the mono the higher the percentage PWM. When pulse rate meets the mono time you are at 100%.
No pulse = 0%. Needs some safety logic, like requiring a minimum pulse width, so noise can't start the VFD when stopped.
That way PWM distortion from the computer end is solved. You can have the best of both worlds this way.
A standard VFD with analogue input, and step/dir signal so it is all digital, where the noise matters.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 12-09-2011, 11:33 AM
Is it safe to assume that professional PWM amp designers have thought of this? For example this Pico drive: Pico Systems PWM Servo Amplifier
Old 12-10-2011, 12:33 AM
neilw20's Avatar
Cool Hope this helps, and opens a few eyes.
Looking at the specs, it says only 3mA is needed for the opto.
Without knowing what opto is used I can only lead with these comments...
In my experience, so far, suitable optos need to driven at 6mA to minimize PWM distortion and speced in the 10MBd range, like ACPL-M61L typically 6nS error. Well under 0.1%, and it's output is CMOS suitable to drive an integrating circuit, which must be charged AND discharged at the same drive current.
A PWM of between 25 and 100KHz need high speed devices well into the MHz range.
A 4N35 has a time difference 18 off and 9 on, of 9uS. At 100Khz that is 50%!!!
A 6N137 has a time difference, of 35nS. At 100Khz that is under 1%
Problem is caused by the difference in rise and fall time.
The output of the opto coupler needs to drive a very accurate pulse width and height to integrate the PWM signal. This needs to be independant of temperature changes, and that is another story.
Many devices are not up to the task if precision is required, and the output side needs using the PWM has to maintain accuracy.
At mid range, you won't notice much error but at each the low and high ends the error can be easily measured with a tacho.
And all that aside, the perfect PWM signal has to presented to the PICO systems unit. Read back my previous using the set/dir signal so that all the errors are only at the decoding point.
A soon as you take PWM from a PC or similar, errors are inevitable, without special attention to propagation delays all the way to the recovered DC signal.
Old 12-10-2011, 11:18 AM
I think you are over thinking it..
This is what a motion guru says.
All this accurate PWM stuff is rather silly if theres feedback loop around it
And that is what emc2 can do..
sam
Old 12-10-2011, 11:40 AM
SWPadnos is on a distinguished road
What's easier with step/dir is that there is no need for feedback to the PC, since step motors only move in "steps". (ie, since each pulse theoretically corresponds to a specific amount of motion, all the computer has to do is output the right number of pulses for whatever distance it wants the motor to move)
A second perceived advantage is that they are generally somewhat less expensive, especially when you take the cost of the feedback components into account.
- Steve
[IMG] code is Off
Need Help!- Loosing step more and more on X axis only after reducing the accl/velocity step motor Calico DIY-CNC Router Table Machines 3 04-09-2010 07:23 PM
Need Help!- Step/Direction pins should be Step FWD and Step BACK rayscott Mach Software (ArtSoft software) 6 02-09-2010 05:57 PM
Full step and half step hybrid driver? rkremser Stepper Motors and Drives 4 11-20-2008 10:22 AM
Need Help!- How to edit MPFAN post file step by step m_bhui Post Processors for MC 2 10-04-2008 05:42 AM
Step by step cnc plasma with parts list and links. massajamesb CNC Plasma and Waterjet Machines 8 07-08-2007 10:22 PM
