Old 12-01-2011, 08:20 AM
ishaqahmed is on a distinguished road
48vdc Brushless DC SErvo motor upto 200 oz-in
Dear Members,
Kindly help me to find 48VDC BLDC servo motor with upto 200 oz-in rated torque.
Please its urgent. suggest plz.
regards,
Ishaq
Old 12-01-2011, 10:02 AM
Al_The_Man's Avatar
What is the make of the one you want to replace if this is the case?
You may have a limited source as 48v is fairly low for most BLDC which tend to start at ~100v.
Tamagawa is one make that MAY have a 48v if you can find a surplus one.
Old 12-01-2011, 10:11 AM
Thanks for your reply,
Thats true I can't exceed 48VDC as it is the max battery source I have.
I have searched for different DC Servo motors, Plz suggest Can I use below mention motor.
Torque requiremnt =200 oz-in
Voltage source =48VDC
SM34165DT
Will it help me.....
Regards,
Ishaq
Old 12-01-2011, 10:15 AM
Al_The_Man's Avatar
I have had no experience with that motor but it appears to show RS232 communication, if so you would need a compatible controller with the correct software.
What is the nature of the command signal you intend to use?
[IMG] code is Off
DIY Brushless Servo Motor ? epineh Open Source CNC Machine Designs 11 06-14-2009 10:29 AM
Brushless DC servo Motor lavrgs Tree 1 05-31-2009 10:47 PM
3 ph ac brushless synchronous servo motor sakarya83 Want To Buy...Need help! 1 10-25-2008 06:43 AM
Bought a brushless servo motor, now what? draemr Servo Motors and Drives 5 07-14-2008 07:01 PM
Affordable DC Brushless Servo Motor Lemo Servo Motors and Drives 0 08-21-2007 07:10 AM
