| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
hello folks, I am building a metal mill for cutting pure steel. Weight will be around 300kg. work area is 12x12x12. it is having 15mm lm guides, 1 inch dia of ball screws and something to drive them. I have little experience with steppers as i have two of them on my lathe but know nothing about servos. I want to use servos on the mill because there is no place for missing steps. How many watts will be enough for a mini mill. I will not be using very big tools on it. Just 3hp spindle, 2000rpm and not more than 3inch dia of tools (facing tools sometime) If i have to go for steppers, i have an eye on the 22 n.m. (3000 oz/in) steppers from ebay. But i don't want loose steps and scrapped parts so i guess servo route is better. please put some light here. with thanks, jasminder singh
__________________ It is better to die for something than to live for nothing. |
| Just a data point for you. I have a similar size mill with 1/4 hp. servos and 2:1 reduction to the ball screws. plenty of torque. i did use steppers on this mill for a while and had trouble with missed steps. Karl |
| Go for 400W servos for starters with some reduction since you are cutting steel (not high speed requirements).
__________________ http://www.cnczone.com/forums/cnc_wood_router_project_log/125895-my_diy_cnc_cnc2011_%3B.html |
| What do you think about this? SAMSUNG 200W SERVO PACK,DRIVER MOTOR 3-AXIS CNC,ROUTER | eBay i don't know about price range of new 200watt servo in india. Recently talked to a guy in a expo who was charging 1000$ each set (servo+drive) delta 600watt system. BTW what should i look for in a servo system in case i am planning to buy 3 new sets. I guess encoders should have more than 1000 cpr (0.0005 inch resolution is fine for me) and with a 5mm lead ballscrew, such encoders will get me the desired resolution. I want to know what else i need to look in servo drives? like in steppers, there are bipolar that are better than unipolar. Some have thermal and short circuit protection. Some have high speed choppers that keep the steppers cool. What cookies are in servos that i should look for when buying new motors and drives. BTW how good that ebay deal is? jasminder singh
| jasminder 200w is to small for that kind of work the smallest you could go would be 400w, Dmm have the best package for the money You can see one working here, on my build http://youtu.be/iTBr_rJXZSw Motion Control Products - DMM Technology
__________________ Mactec54 |
That looks to be a nicely matched system if you're going with Mach. Its pretty small. My guess, if you're willing to gear it down about 5:1 you'd get enough torque but at a loss of top speed. For anything you build, I'd allow for trying different pulley sizes to optimize torque vs. speed. Karl |
i will try dmm tech or contact a local supplier of delta drives and motors for good price. With a local purchase i can get good service and repair (i am very good with frying things. lol..) i am planning for a direct drive but let's see what happens. BTW do you think 16mm hiwin rails are enough for such a 12x12x12 mill? jasminder singh
Very neat and clean machine you have built. I guess you are having a big lead on your ball screws cuz they don't seem to have a 5mm lead. But that is good for routers where you can sacrifice in tolerances and need rapids. best wishes for your build. jasminder singh
#10
| Second Mach, of course 16mm pitch screw sacrifices tolerances compared to a smaller pitch like say 4mm! Your encoder will produce 4x less resolution than on the finer pitch screw! Mach, a lot of folks come here for genuine help: for you to give such bad info is a disservice to this forum..
__________________ Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit |
#11
| And, Although it does not immediately resemble it, a ballscrew resembles a class 1 lever, the fulcrum is the centre of rotation and the diameter is the effort, increase the dia lowers the effort, the load side is the screw pitch, decrease pitch shortens the load side and lowers effort. Al.
#12
| mike_Kilroy (Quote) of course 16mm pitch screw sacrifices tolerances compared to a smaller pitch like say 4mm! Do you even no what tolerance is No there is no lost tolerances, Just uses more encoder resolution, & there is plenty of that at 14 bit 16,384 count Per revolution, Positioning is still better than .0001 with there system & the 16mm pitch ballscrew, What more could you want?? Nothing misleading about say Dmm have the best package for the money, You show me another one that can come close to there Performance, Reliability, Ease of Setup, Service & Cost
| Stepper motors or servo required? | vwdevotee | Stepper Motors and Drives | 4 | 06-21-2010 03:39 PM |
| Question regarding servo drives and ratings. How much speed would I lose? | radioactive | General Metal Working Machines | 18 | 02-26-2009 09:12 AM |
| Requirements for Linear Slide Ratings for a mill | bprzybyl | Mechanical Calculations/Engineering Design | 2 | 04-24-2006 11:49 PM |
| calculating Servo Motor ratings | OwenL | Benchtop Machines | 2 | 03-17-2006 11:27 AM |
| FANUC Servo Amp Manual required | woodglass | Commercial CNC Wood Routers | 0 | 09-09-2005 01:44 PM |
