| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Am Planning on fitting a knee mill with 2 and eventually 3 axis operation. Been looking at some Ac Servo Motor/Drive combos. Looks like most commercial knee mills w 9x42 table use motors around 27-29 in/lb with 41 optional. Should one look for low or medium inertia motors? Will have 1" or 32mm ballscrews. Could one "get by" with 750 watt 2.39NM cont. 3000 rpm motors? I only do onesy-twosy jobs. Rounding corners, pockets, bolt patterns. Max performance not needed. Also, in drives, I assume they work in "position" control mode in an application like this. Centroids kits for 3rd party drives have a +-10v control signal for the drives. Some drives only work in position mode with step and direction. Any advice appreciated. tvan56 |
| It all depends on the controller you are looking at and the speed of operation as to using low inertia motors. Many hobby controllers use step/dir and require drives capable of closing the loop. The type of controller that uses ±10vdc can use non-intelligent drives where the loop is closed back from encoder to controller. There is a motor sizing program on the Kollmorgen site. Al.
| Looking at Delta Electronics ASD-B2-0721-B Drive and ECMA-C20807 Motor from Keling. It has inputs for the encoders on the drive and pass through encoder signals for a controller. Would that work with the Centroid system? Not wanting to do high speed work. I am aware of motor sizing programs. I don't know the weight of the table, the acceleration rate, screw inertia,etc. My problem, I realize. I have been a manual machine guy forever. I am just looking at what is out there as to what others are using. Do low inertia motors lend themselves to quicker moves due to low inertia? If one where to have two equally sized motors driving the same load < 10:1 inertia, and one was low inertia, the other medium, what would the characteristics of each combo be? |
| tvan56 If you are going with Centroid control, you will have to use what Encoders they spec for there control, it would be best just to get the whole package from them Ballscrews 32mm would be correct for a machine that size
__________________ Mactec54 |
| Will check into the encoder thing. About the screws. Hiwin has 32mm dia. jobs. Weak Yoke. Elrod offers, I think 1" dia. and strong yoke. Just from looking at pics, I'm guessing Anilam uses same screws as Elrod. Jena-Tec We had a prototrak where I used to work. It had rather small looking screw. Never measured it. I think it was rolled also. I guess SWI maps their screws or something, because that machine could do some good work. I think Rockford Ballscrew may offer a 32mm because the pics show the ball return tube protruding through yoke side, like Hiwin. Worried about the single "preloaded" nut issue and backlash. |
| so t=11w/T or =15w/T hence low J motor will be accel in 11/15 or in 73% of the time of the med J motor.... for single parts u say u will do, do u think this will make a hill of beans difference? prob not. 2) see 1. other thing is if u do pick the single nut screw with backlash, the load is only 10/5 or 2x the inertia of the load. the low J is 10/1 or 10x more. the 10x ratio MAY be SIGNIFICANTLY HARDER to tune to make good accurate cuts so if u dont need to save that 100-73 or 27% of the med inertia accel time of 1/2 sec, then pick the med J motor in a heartbeat.
__________________ Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit |
| tvan56 I am running a Tree 2UVRC with Emerson MG-316 (750W) servos driven by EB-205 drives for X and Y (~32lb-in). Z axis (entire knee) is driven by an MG-208 (480W) servo and an EN-208 drive (~27lb-in). Z axis has a 10:1 gear reducer on the servo and a reduction through the belt drive as well. Not sure what the exact ratios are but I can get them for you if you are interested. I get over 100 IPM in X/Y . Z is more like 30IPM I think. I would think 500Watt motors should get it done if you aren't looking for max performance. --bob |
| Thank You all for the advice and wisdom. Mike, that explanation of yours made some light bulbs come on inside my head. Will continue researching. Tuning ease is one thing I want to be able to do easily. I was working at a place in the mid '80s and was responsible for programming and interfacing a Cincinnati Milacron T3-776 Robot. Those things were a bear to tune. Just trimpots. Seemed like hit or miss. Throw some backlash in and It would shake like hell in is moves, hunting. You had to loosen it up so much it looked like the thing had arthritus. Sluggish as hell. Replaced the worn screw and then on could stiffen it back up. They were monitoring speed at the motor with a tach and position elswhere on the arm for position with a resolver. |
#10
| Here I am posting to my own reply, but just thought I would put some stuff out here about myself and my thoughts. This servo stuff is not new. I am an old vacuum tube radio guy. It simply amazes me what was done in the old days with tubes. Regenerative radios in the '20s used positive feedback to intentionally make them oscillate. They would then just tune to the edge to get fantastic signal gains. In the late '50s Harmon-Cardon made an amp that is still a benchmark today. Citation II Triple! nested feedback loops. Here is something I found: There are three nested feedback loops. The first is from the plates of the phase splitter tubes, to their grids. The second is from the plates of the output tubes to the grids of the phase splitter tubes. The third is from the output transformer secondary to the cathode of the input tube. The total amount of feedback is about 32 dB. This about 10 dB more feedback than a traditional Mullard or Williamson type tube amp. The multiple loops, and fantastic output iron make this possible. The time constants of each loop have been carefully calculated. 10 KHZ square waves (at about 2/3 power) look amazingly good, with just a tiny hint of ringing (one period). This amplifier is amazingly stable for any tube amplifier, let alone a tube amp with that much feedback. One thing that we learn from history is this. We don't learn from history! The older I get, things that seem so unrelated earlier, are the same. Sidetrack over... |
#11
| I could always dig up some of my old prints on Thyratron closed loop drives, you may have a problem getting parts however. ![]() As a guide for your retro-fit, I bought some Excello knee mills that were originally professionally retrofitted, but the controller supplier had gone out of business so they had to be re-retrofitted! They have a DC servo 40lb-in with 2:1 reduction, ball screws are 1-1/8th" dia. Note: The reduction increases the torque at a ratio of reduction, and the motor-load inertia ratio is decreased by the Square of the reduction. Al.
#12
| sounds like u, Al, & i could tell some cool old time stories!
| Question ? - What hobby CNC servo driver will drive a 12Volt DC motor | FPV_GTp | Servo Motors and Drives | 25 | 10-27-2010 01:37 AM |
| New Machine Build- Which drive for Ac Servo motor. | ahmedrehan | Servo Motors and Drives | 0 | 08-17-2009 06:19 AM |
| Need Help!- AC Servo Motor Drive | danieltmedlin | Want To Buy...Need help! | 1 | 03-14-2009 10:52 PM |
| Servo motor drive | IanH | General Topics | 0 | 06-09-2008 12:35 PM |
| Sell Servo Motor, Servo Drive by GSKcnc.com from China | salecnc@hotmail | Product Announcements & Manufacturer News | 0 | 06-03-2008 02:55 PM |
