Old 11-14-2011, 10:42 AM
rabbc is on a distinguished road
galil 2180 and amc amps
Hi I'm new to CNCZone , this will be my first post. I've been building a CNC router for a number of years and now
that I'm retired I have time to finish it. All I have left is the wiring etc. I have a Galil 2180 with Galil ICM 2900 and I am connecting to
Three AMC BE25A20AC Amps Two of these amps have INV , (not -INV)at the end of the model code and two have a D at the end
I am using Brushless DC motors and hope to run in Torque Mode. My computer seems to be talking to my galil 2180.I'm not sure
on the settings and wiring. I have Galil tools up and running but its greek to me. So any help would be great. Anyone have a machine set up like this? I have a image i'll try to post as well ( it is attached)
But not sure how. Rick
Old 11-14-2011, 11:04 AM
Al_The_Man's Avatar
If you have everything hooked up the first thing to check is the encoders, turn them in both directions after each turn, to a TP, this will tell you if they are hooked up and working, the next is to turn the motor outputs on by a SH and then a move command, PA and then a BG.
There is a manual tuning detail in the Galil manual, if you don't have the tuning s/w.
http://www.galilmc.com/support/appno...s/note5446.pdf
Old 11-14-2011, 07:34 PM
Encoders seem OK
Thanks Al, first off I had to figger out what TP SH etc meant, I had seen those somewhere in my reading so went looking. I printed all the Galil Commands and tried out the ones suggested. I powered up the encoders and turned the motor shaft first one way then the other. The light on the Amp stayed green (i'm only working with one axis/motor right now)The numbers went positive and lower and back to neg as I turned it one way and then the other. I tried TP and the number matched what was shown on Galil Tools Terminal. I noticed the axis fault numbers showed as the opposite as the encoder numbers is that correct? I then turned off power to amp and connected the motor power ,restarted power, light still green, using the terminal i entered SH then PA 10000 and then BG. No Movement.
The KD,KP and KI sliders at the top of Galil tools I had set to zero , if I move KD nothing happens, move KP and motor goes clockwise, move KP back to zero it stops.
The KI slider does the same, same direction etc. The error light on the Galil 2180 comes on Red. It would have been sweet if the motor had moved with the BG command. If you look at my Attachment you can see what I have hooked up or not. A to A , B to B Etc
Any help is very much Appreciated.
Rick
Old 11-14-2011, 10:56 PM
Al_The_Man's Avatar
The BG has to have a axis letter, e.g. BGX etc.
also PA has to be assigned depending on axis, PA10000 = X or PA,10000 = Y.
The -ref on the amp does not seem to be connected to D(Gnd)?
also how come you used a separate supply for the halls and not use the Amp power supply or 5v from the 2900?
the HALL-C does not show connected on the print?
With the halls connected and the amp power off, turning the shaft the LED should stay on on the drive, if it goes to red then the hall sequence is wrong.
Also, once you have the drive hooked up, it may need the motor direction phasing corrected if it runs away.
via the MT or -MT command.
Old 11-15-2011, 12:00 AM
AL thanks for the info, Hall 3 line just disappeared when I resized the image I guess, -Ref is connected to GND. So I tried using the proper commands but I still get a error that reads as follows 2010 command error Galil::Command (BG X)got? instead of response. TCI returned "22" not possible due to limit switch. I have no limit switches installed.
Rick
Old 11-15-2011, 12:12 AM
Al_The_Man's Avatar
You may have inverted input IC on the 2900, do a TS (Tell Switches) it will show the decimal value of the switches look in the TS XYZ instruction for the fwd rev inputs for each axis Bits 2 & 3, convert the decimal to binary.
You may have to provide a pull up or pull down for these depending on how they are configured.
Old 11-15-2011, 07:27 PM
Al I did a TS command and all switches are 35, After that you've lost me, I did go into the watch program where they show the value of each switch.
They are all zero.Rick
Old 11-15-2011, 08:21 PM
Al_The_Man's Avatar
If you convert that to binary to look a the state of each bit, 35 is 00100011.
Which means the fwd and rev L.S.'s show tripped or equivalent to activated (2 & 3).
Therefor bit 5 (MO) is also off.
You have to change the logic of the fwd rev L.S.'s to clear it, by wiring the inputs to I believe the +5, if that doesn't do the trick, try to common (GND).
When the motor is not turning, the inputs would typically read 15 00001111.
This is if the SH is on or no MO has been activated.
Old 11-15-2011, 09:41 PM
AL some more clues I have found, The ICM 2900 has a little white tag that says OPTO on it, plus the 2180 also has a opto Dip switch but it is turned OFF. I'm searching and reading sorta learning a little as I go. I'll stick with it until I get it working. I really don't know much about electronics or progamming but I can build things. I was a shop teacher, Woodwork and Drafting, AutoCad Mastercam etc. I had to Sub today ,so not much spare time.
Thanks again for any help
Rick
Old 11-15-2011, 09:49 PM
Al_The_Man's Avatar
You have this version, http://www.galilmc.com/support/appno...a/note1427.pdf it has opto isolated outputs, you may have an inverter IC for the inputs, this is why they are tripped.
I will look the rest of my Galil data sheets out tomorrow.
  #11   Ban this user!
Old 11-15-2011, 10:32 PM
I put 5v to limits in, TS number in now 3, I hooked up GND to limits in, and TS number is 3
I disconnect all wires and TS stays 3 I reboot 2180 and TS stays 3. The motor will spin if I give it just a slight start. It will stop when I slide KD,KP, and KI to zero, but no motion from the BGX command Rick
  #12   Ban this user!
Old 11-15-2011, 10:51 PM
Al in the watch program the value of the limit switches has changed to 1, I don't know how I did that, I guess with the TS being 3 it changed the value. But motor still not moving . Rick
[IMG] code is Off
low amps gaffa General Electronics Discussion 2 03-02-2009 10:50 PM
Help with AMC amps ka67_72 Servo Motors and Drives 37 02-19-2009 06:51 PM
2.5 amps per phase drive - 2.8 amps per phase bipolar motor ... kochevnik Stepper Motors and Drives 6 10-22-2006 10:48 PM
How many amps ? bgolash General Electronics Discussion 1 03-09-2006 07:48 PM
Howto find input amps, from output amps on transformer? sendkeys General Electronics Discussion 7 07-14-2004 07:13 PM
