| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Hi everyone, I have aquired some large Parker Motion Linear actuators that I want to turn into a CNC router. The controller and drives were disposed of before I had a chance to claim them, but were probably of no use to me since they were anolog torque/velocity drives. I am now trrying to figure out what I need to run these with Mach 3. My first machine was stepper based so I am new to servos. I contacted Parker and I told them I needed a driver that would take step and direction inputs from a PC and they gave me P/Ns for Compax3 drives. According to the specs for these drives, communications are via RS232/RS485, and the command sinal is +/- 10V, Step & Dir, or Encoder. Will these drives work with Mach 3? If so, is there anything alse I need between the PC and the drives? Any information would be greatly appreciated. Thanks!! M3ocd Beau |
| they shud work. anything else needed? do they have power supply built in? if so prob not/. there are a couple companies on here that advertise and have similar that prob will work, prob for 1/2 the price too. one i heard of is gecko? another similar too.... check with them if u want options....
__________________ Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit |
And to answer your question " is there anything alse I need between the PC and the drives" you will need from start to finish....PC (running Mach3)-breakout board-driver-motor and in that sequence.... Have a look at these links for informative purpose and a starting point, have a look at the pdf specs of the motors and drivers and you should find a suitable product to output the required torque you need....CNC Stepper Motors: Stepper Motor Distributor in USA http://http://www.cnc4pc.com/Store/osc/index.php Warp9 Tech. Design - Home of the SmoothStepper - Home Good luck with your project
__________________ Eoin |
| Thanks for the info. The actuators are Parker HLE100 series actuators with about 8 foot of travel, and the z axis if a Parker actuator with about 23 inches of travel. The servo motors are quite large, I think (2) of them draw a little over 6amps and the other one draws almost 15 amps. Again, thanks for the info, and I'll post what I find out to help others. M3ocd Beau |
| Tags |
| compax3, compumotor, mach 3, parker, servo drive |
| (2) Compumotor S83 motors, Encoders, & Zeta4 Drives | Bulldogce | EBAY ADS | 0 | 08-09-2011 02:43 PM |
| Need Help!- Compumotor Servo Drives? | CATCH22 | Servo Motors and Drives | 0 | 05-11-2011 08:17 PM |
| AH-DRIVE-S/1407 Parker Compumotor Stepper Drives | m8kingit | Controller Cards | 2 | 12-29-2009 01:17 PM |
| servos, drives, p/s | scudzuki | Benchtop Machines | 8 | 02-08-2009 06:02 PM |
| servos (encoders, drives) | gv71 | General Electronics Discussion | 3 | 03-31-2004 12:43 AM |
