Old 10-25-2011, 02:30 PM
Rencio7's Avatar
Rencio7 is on a distinguished road
Exclamation Newbie Identifying Servo Motor
Hi I am looking for some info on some Pittman servo motors...
Here is all the information I have so far..
Pittman
6501033
Rev D
24VDC
400 CPR
05-23-00 (Date?)
9434J817-R1
thanks and any information on which servo drive I'd need..I'd be very greatful..I'm not even sure what type of servo they are BLDC etc..?
I am new to the servo motor world.
I have the other stuff sorted out I think..
Here are some contenders for servo drives : -
Tell me if they are suitable.
DeskCNC
GeckoDrive
Many thanks!
Rencio
Old 10-25-2011, 02:52 PM
Rencio7's Avatar
Ok I found some (similar looking and spec wise) models of servo (Pittman) and some datasheets...so it looks like they have inbuilt hall effect and hp encoders..but I can't be sure..
any experienced pittman users around?
Old 10-25-2011, 03:05 PM
Al_The_Man's Avatar
Pittman are typically small DC brushed motors.
The 24vdc limits them a bit.
If you can post a shot of the encoder end it may be possible to identify the encoder?
Old 10-25-2011, 03:42 PM
Rencio7's Avatar
Thanks for the reply Al..
I will get a photo of the encoder soon.
It will be for a low load application so the servos don't have to be super strong.
If brushed dc I think I will probably go for the deskcnc drives..the encoder has 5 wires coming from it if I remember correctly - I'll have to check again over at the studio..
If 5 wires it's probably a 2 channel encoder like on the datasheets I've seen..right?
Ok I'm not sure about the hall sense assembly..is that to do with endstops?
The servo has a 1 and 2 with 2 wires from each - this is different to the datasheet with hall sense.
thanks
Rencio
Tags
pittman servo motor
[IMG] code is Off
Newbie- Newbie- Servo motor torque question byrdman73 Servo Motors and Drives 4 06-09-2009 06:41 PM
Help identifying servo Wolfmarsh Servo Motors and Drives 3 03-12-2009 08:08 AM
Identifying SEM servo motor torque boringmill Servo Motors and Drives 1 12-26-2006 10:22 PM
Newbie: is there difference between stepper and servo motor? g888h Stepper Motors and Drives 4 09-10-2006 07:50 PM
Help identifying servo motor Corvus corax Servo Motors and Drives 1 10-25-2005 09:34 PM
