Old 10-09-2011, 08:02 AM
GANESHAN is on a distinguished road
TORQUE
HELLO FRIENDS,
THIS QUESTION MAY LOOK ABSURD BUT PLEASE HELP.
WE ARE USING A SINGLE PHASE 1HP INDUCTION MOTOR WITH BELT DRIVE FOR SOME POWDERING APPLICATION.
TO INCREASE THE TORQUE SHALL I GO FOR A GEARED MOTOR WITH SAME HP.THE RPM OF THE RUNNING MOTOR IS 1800RPM.SHALL I REDUCE THE RPM THROUGH THE GEARED MOTOR TO INCREASE THE TORQUE.
THANKS,
GANESHAN
Old 10-09-2011, 08:58 AM
yours_prabhat is on a distinguished road
Dear Mr Ganeshan
You can use a Gear Box to Increase the torque or you can use Reduced Voltage Soft Starters (Reduced Voltage Soft Starters are used to limit the starting current and reducing the Locked Rotor Torque or Starting Torque and are common in applications which is hard to start or must be handled with care - as positive displacement pumps, cranes, elevators and similar.) or The best is you should to use the Single Phase VFD drive Because your application requirement is Accelerating Torque You can calculate Simply Accelerating Torque = Available Motor Torque - Load Torque
regards
Prabhat Mishra
prabhatmishra@gmx.com, +91-9430737981
Old 10-09-2011, 06:22 PM
mike_Kilroy is on a distinguished road
Ganshan,
HP=T*N/5252 where T is torque in #-ft, N is speed in rpm.....
so T=5252*HP/N
example: so if u gear N down 10:1 then T goes up 10x.
seems u know this already, so what is ur real question?
Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit
Old 10-09-2011, 06:25 PM
Originally Posted by yours_prabhat View Post
Dear Mr Ganeshan
regards
Prabhat Mishra
perhaps one Indian to another, this may make some kind of sense. IF not, please disregard this post as it is complete garbage.
Old 10-10-2011, 05:42 AM
THANKS
Thanks for both gentlemen for their valuable input.
GANESHAN
[IMG] code is Off
Constant Torque vs. Varaible Torque VFD robhrzic Phase Converters and VFD 24 02-16-2012 07:46 PM
Holding torque vs rotational torque ? SScnc DIY-CNC Router Table Machines 11 05-06-2010 07:41 AM
higher torque 5 start, vs lower torque 2 start carvemylog DIY-CNC Router Table Machines 8 03-11-2009 10:44 PM
Torque lgalla Phase Converters and VFD 3 12-31-2006 03:33 PM
Can I Get More Torque? cbcnc DIY-CNC Router Table Machines 38 04-14-2004 03:47 PM
