Results 1 to 3 of 3
Thread: CNC bport clone, dead controller- good servos
    Jan 2007
    Question CNC bport clone, dead controller- good servos
    I have an opportunity to buy a Taiwanese Bridgeport clone that was retrofitted with ball screws (3axis), servos and a bandit controller. Apparently the bandit controller is having problems, and the seller wants to sell it for $500. It has an autolube system.
    My inclination would be to dedicate a PC to it running Mach or something similar. I basically understand the approach when you have steppers- get a gecko board, hook to PC.
    But what is the affordable approach to driving servos? Do servos use a closed loop and feedback from glass scales or what?
    Any help/advice would be appreciated.
    Thanks-
    lkasdorf
    Feb 2009
    I think feedback on servo's come from the encoders. It is my understanding that the encoders attach as part of the servo drive shaft, usually at the back end.
    Have a good one,
    Jawno
    May 2007
    Check in with the guys on the EMC2 board.
    EMC is not limited to step\dir outputs it can work directly with servos.
    If the servo motors and drives are in good shape you could have all the advantages of a full servo system for not much money.
  1. BP Clone Controller upgrade
    By Bigbloke in forum Bridgeport and Hardinge Mills
    Last Post: 05-18-2010, 05:11 PM
  2. Need Help!- Help! dead controller on Fanuc 0ma
    By DerHammer in forum Fanuc
    Last Post: 06-05-2009, 10:50 AM
  3. Bridgeport Clone Anilam Controller problem
    Last Post: 03-01-2009, 06:54 PM
  4. Ametek Servos on a RF45 clone
    By sprintcarfan in forum Benchtop Machines
    Last Post: 11-19-2007, 09:59 PM
  5. Controller is dead!
    By CNC_Newbi in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 06-13-2006, 05:26 AM
