Old 10-03-2011, 06:25 AM
parametric.ms is on a distinguished road
Diode at Transistor Modul
I have a problem with my spindle drive A06B-6055-H103.
After I changed two diode that mounted to transistor module, If I start spindle CW or CCW, the resistor module at connector 6-7 (4 ohm) keep always burnt (I've changed twice for resistor)
maybe I miss hook up diode at transistor module, because I'm not really sure where is anode or cathode goes to.
Does anyone can help me where is the right position for two diode at transistor module?
(diode with red stripe and 4 blue dot)
[IMG] code is Off
A03B-0815-C001 FANUC I/O MODUL CNCadmin EBAY ADS 0 07-12-2011 03:00 AM
Need Help!- Diode value. hotrob1 General Electronics Discussion 5 05-19-2010 06:37 PM
Standard Diode vs Fast Diode for stepper driver Almaz Stepper Motors and Drives 10 10-10-2008 01:57 AM
HEDS-9100 encoder modul giorgiocnc General Electronics Discussion 4 09-11-2006 03:04 AM
Diode selection help bgolash General Electronics Discussion 25 08-09-2005 02:41 PM
