I'm sure it's useful.....stick a load on it...and you can determine how useful.
335 RPM on 12 VDC .38 amp no load
650 RPM on 24 VDC .51 amp no load
975 RPM on 36 VDC .62 amp no load
3 amp stall
Shaft 1/2" dia x 1-1/2" (no keyway)
4" diam. x 9" long
this motor is made by pacific scientific and i don't know if it has an encoder.
i don't want to buy it and find out that i can't use it. i'm looking at converting a RF-31 clone
Well, now that they have updated their web site to include max voltage of 60V, I ordered the last two for my lathe! Based on my spreadsheet info gathered from Marris, they should do fantastic.
Hope you got some as they should do a mill very well.
Art
Okay and which website was that??
i had found these motors on surpluscenter.com apparently so did alot of other people after i posted this. originally there were 32 motors. i was going to buy some but i already have some smaller motors that my drives are setup for and i really can't afford to switch mid stream and start over. this is my first cnc mill build and i will eventually build a square column version to replace this one. until then i won't need the bigger motors and i'm some more will come along sooner or later.
