| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
| Watts = volts x amps. You can have 2 motors with the same power (watts), with a large difference in torque.
| Watts is a measure of power (work) i.e. voltage x amperage, Torque x RPM. If a motor is generating 500 oz/inches with 0RPM then no work is being generated (500oz/in x 0RPM = 0). To convert torque to watts you will have to include the RPM in the conversion. |
To get Watts, speed must be expressed in radians/second. To get this: 1 rev/min * 2PI radians/rev * 1 min/60 seconds = 0.10472 rad/sec. So 1500 rpm = 1500 * 0.10472 = 157.1 rad/sec. Torque must be expressed in Newton-meters. To convert, note that 1 oz-inch = 0.0070616 Newton-meter. So 300 oz-in = 2.12 N-m. The motor will be delivering 157.1 rad/sec * 2.12 N-m or 333 Watts. 746 Watts is 1 HP, so 333 Watts is 333/746 or 0.45 hp. The motor will have zero power output when stalled (rad/sec=0) and at max no load speed (output torque = 0). Peak output power will be at 1/2 the max no load speed for the given supply voltage. The difference between the input power (V*I) and output power (speed*torque), at a given speed is, for the most part, what is turned into heat (I squared R losses). A very little amount of the loss is due to internal friction and viscous losses. The ratio of output power to input power is the motor's efficiency. Hope I did my math right or I'll be totally embarrased! Lance |
