| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
so i've decided to wander into the world of CNC and make a small gang tool lathe to crank out parts. the mechanical side of things will be easy for me but i'm totally clueless when it comes to the electronics. so far i have acquired a trio of mitsubishi drives and their matching servos, all of them are the MR-J2-xxC-S100 model. i am at a total loss on how to hook these things up to something like MACH3. other than RS-485 the only thing i can see on the data sheet that resembles a way to control them externally is the MPG connection....and neither look like they would work with MACH3. i need a good bit of guidance here to say the least. the manual: https://my.mitsubishi-automation.com...er.php?id=1373 |
Outputs A1 and A2 would connect to pin 3( PP) and pin 2 (NP). Do not forget the NOT gate in the design. You should test it on a disconnected motor for safety. In other words you need a high speed digital switch where you can switch a singe input to 2 outputs. Hope this helps, Iron-Man |
| now i'm wondering how it would all work out timing wise. certainly there is some kind of delay between the direction signal and the step signal in mach3? i mean other types of drives have to have time to process the change in direction as well, right? and in the attachment below: what is this "open collector system, differential receiver system" stuff? to me it looks like code for "connect me wrong and i fry"... |
Here is another CNCzone link, study this: http://www.cnczone.com/forums/genera...ir_cw_ccw.html For your application, I believe that you only need pins 3(PP) and 2(NP). The above link may provide a better solution depending on what chips you have access to. The propagation delay will probably not be a problem. Mach 3 will generate the timing signals, just make sure that whatever device you use it is faster than Mach 3. You should prototype it on a bread board. An oscilloscope would be helpful if you have one. The link above uses 7400 ICs, see this link for specs: 74 Series Logic ICs The 7400 series has an operating frequency up to 25 Mhz. The 4016 has a operating frequency up to 40 Mhz :http://www.cedmagic.com/tech-info/data/cd4016.pdf The set up on page 6 of the manual must be for a MPG with differential output. Just try pins 3 and 2. Forward Pulse, Reverse Pulse. At 25 Mhz or 40 Mhz there should be no problem using Mach 3. See this link: http://www.cnczone.com/forums/mach_m...do_100khz.html Hope this helps, Iron-Man |
| thanks, looks like some good solutions are out there. need to dig the servos out to see what kind of pulse rate i need. also looks like there are much higher speed versions of that IC like the 4066 that can handle switch rates way up in the MHz range. and i do have an old but working 'scope but the controls and the manual are in russian might be time to get my neighbor over to do some translating... |
| i haven't seen that drive in person, but looking at connector pinouts in the manual it lookes like that the hardware is identical to the A-series drives. if it is, you can try to reflash it with the A firmware. wanna try? edit: oh, that J2, not J2S. i don't have the firmware for it. have to find any J2-A drive first... |
| that's an interesting idea even though my track record with firmware reflashing isn't so hot....the more expensive something is the better my chances of bricking it... anyways, i would wanna scrutinize the guts of both before taking that route. when i dig mine out of storage i will open it up and take some hi-res photos. |
| You should find the solution here ---> http://www.cnczone.com/forums/servo_...tml#post597464 Go through all 11 pages, I have mine MR-C20A connected in similiar way. |
any first hand real world info is next to impossible to find.anyways, i've dug them out of storage and will soon start poking them with a stick to see how they respond... |
| Problem- Mitsubishi FR-SGJ Spindle Drive | mikwest | Mazak, Mitsubishi, Mazatrol | 8 | 04-29-2010 04:03 PM |
| Need Help!- Mitsubishi Spindle Drive Alarm | Antonio Arguijo | Mazak, Mitsubishi, Mazatrol | 3 | 01-27-2010 12:03 AM |
| Need Help!- Mitsubishi servo drive | hotrob1 | General Electronics Discussion | 1 | 08-10-2009 08:00 AM |
| Mitsubishi VX-20 Floppy Drive Help | ltkettch17 | EDM Machines | 2 | 04-28-2009 01:42 PM |
| Problem- Mitsubishi DL MAZ Spindle Drive | nnpepe | Mazak, Mitsubishi, Mazatrol | 2 | 03-27-2009 04:30 PM |
