Results 1 to 3 of 3
Thread: Can't start spindle (servo based) at high speeds
    Mar 2008
    I have a custom spindle that is servo based. If I start the spindle at 500 RPMs I can step it up to 1000 RPMs and have it run well. However, if I try to start it at 1000 RPMs it simply jerks. I have geck320 servo drivers being controlled by a true logic board.
    The machine was running nonstop from July 5th to last week when the problem suddenly arose.
    Mar 2008
    Furthermore, if I detach the encoder there is no fault and the motor runs.
    Dec 2006
    What do you have the fault count for the drive set to? I just cant amagin it not faulting when you unhook the encoder and some kinda hugh fault count is the only thing I can think of out side of driver going bad.
    DO you have another driver to try?
    Jess
    GOD Bless, and prayers for all.
  1. New Machine Build- High Speed Servo Based CNC controller board
    By davidchow in forum Open Source CNC Machine Designs
    Last Post: 05-25-2010, 11:28 AM
  2. PC Based high-end CNC controller
    By CNCcontrol in forum Product and Manufacturer Announcements
    Last Post: 05-27-2009, 03:15 PM
  3. Feeds, Speeds and Depth of Cut for Nickle Based Material?
    By mgb1974 in forum General Metalwork Discussion
    Last Post: 05-22-2009, 07:12 AM
  4. High voltage & high power servo drive design
    By Xerxes in forum Granite Devices
    Last Post: 08-22-2008, 10:24 PM
