| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Hi everyone, I'm a electrical noob so any help (or paper napkin sketches) in the right direction would be greatly appreciated! I've got a Linear actuator for my Z-axis which includes a 24v electromechanical brake on one end which I have no idea how to operate?... I understand that it opens (unlocks) when powered and closes (locks) when unpowered - stopping the z-axis from dropping due to weight when powered off. I have a DMM-Tech setup which is 48v from bob/driver/servo and Im a week away from getting my first machine running...or not if the Z wont move ![]() Tanks |
| you need a power supply suitable for the size of the break a circuit breaker also suitable for the size of the break run the control end of the breaker into your estop loop + power to the breaker from the breaker to the + break the other end of the break to the - power side if your in a rush use two 12v car batteries in series and a switch don't forget to turn the switch on before powering the axis |
| firstyear The brake should have the power on when you first power up the machine, it should not be in the Estop circuit, the brake needs to have power on all the time or you will have trouble with your servo motor, if you don't need the brake it could be removed or made so it is not locking the linear slide ballscrew
__________________ Mactec54 |
| Thanks Mactec54 - I'd like to keep the brake as Im planning on investing in a Doughtydrive b/c head at some point...Including a spindle thats approx 26lb on the Z axis; so any insurance a brake can provide would be much needed. Would you recommend I power the 24v brake directly from a 24v powersupply connected to my main system on/off switch? |
| Hi Mactec54, we just crossed messages ..up late Yes! Girlfriends in bed and I'm fretting over whether to pull the trigger and buy either the Teknomotor 31/40-C-DBS-P-ER20-0.7KW-24000RPM or the ER20 High speed spindle from Arc Euro Trade? Priorities eek. Any suggestions/recommendations (on the spindle not the girlfriend)? |
| firstyear I have not had anything to do with any of these spindles, But any of the Teknomotors I have seen & heard running are quite noisy,See if you can find a video of the Arc Eruo Trade motor running to compare, This Teknomotor video is a bigger spindle than you are looking at but this will give you some idea of one running Teknomotor 1,6Kw + Hyundai N50.flv - YouTube http://youtu.be/HJ2ekYT1c2E
#10
| the breaker looks like this : |
#11
| Thanks so much guys, your helps really appreciated.. In fear of starting a war over which way works best - but mostly due to my lack of knowledge on things electrical; and fear electrocuting myself in a flaming ball... I think I'm going to try and go the direct route and power the brake directly via an independent 24v power supply hooked up to my main on/off switch. That way when I power on my setup the brake releases and vice versa. nice and simple and flame free... i hope When I get a bit more clued up I may try and get tricky by hooking it up to the e-stop, or another pin on the bob and control it through mach3? Think I may end going with an Elte 1.1kw Spindle instead? just seem's to be more info/vids/people using them which can only be good |
#12
| you need to make sure your drives are under power when the break is released or your axis could drift I'm assuming you are using mach3 , check with them to see if mach3 can enable your drives when the estop is released or if you are using a breakout board look to see if you can connect the break relay to the axis enable pinout ? |
| 9 axis press brake help | cnc metalcraft | Bending, Forging,Extrusion... | 1 | 10-31-2011 10:55 PM |
| New Machine Build- Z-axis Brake | Ben Colby | CamSoft Products | 1 | 01-24-2011 02:49 PM |
| New Machine Build- 600mm Box bend brake (Finger Brake, pan Brake) | RotarySMP | Bending, Forging,Extrusion... | 20 | 09-06-2010 10:56 AM |
| New Machine Build- Z AXIS MOTOR WITH BRAKE | Russ Shugg | Servo Drives | 3 | 10-26-2009 02:45 PM |
| adjusting z axis jib with brake | 300sniper | Tormach PCNC | 5 | 08-19-2008 07:19 PM |
