Old 08-26-2011, 05:07 PM
SuperFlyLoser is on a distinguished road
Resolver
Hello, I have a Kollemorgen Servostar CD CR6xxxx. This is a resolver position, AC driver unit that uses 110/220 VAC and can be used for up to 2.2kw 3ph AC motor. I have a Yaskawa SGMSH-20A motor (3ph 2.0kw) that I am going to use for this. I have already removed the Inc Encoder and purchased a Tamagawa TS2013N6xxx resolver and have completed the connections. To include a quadruple check for issues and loose wires, there are none. I'm in the middle of setting up the Motionlink software for this combo.
My issue is that when I get to resolver calibration and I set everything to the "Zero" position and I turn the resolver 180 degrees the software thinks its actually turned 360 degrees. So for every 1 turn the driver thinks its turned 2. I've already thought that it might be the number of poles, so I changed it from "2" to "4" and the issue is still the same. I'm actually at a loss right now as to how to get the software to play nice with the hardware. If anyone knows what I might be missing I would greatly appreciate your help?
I know this is a very abstract issue having all of the differing combination of parts from different manufacturers. I've gone though all the manuals and searched on the net and still have not found anything. I just thought maybe someone here has set up a Servostar with the Motionlink for a resolver before. Thanks for any help!
SFL
Old 08-26-2011, 05:13 PM
Al_The_Man's Avatar
Does the drive expect commutation pulses?
Somehow it probably needs to know the rotor position and you may have an arbitrary position by just installing a resolver?
Just a Guess!
Old 08-26-2011, 05:30 PM
Just a Guess!
The connections to the drive for a resolver are a reference voltage (Excitation), and then a sine and a cosine wave. Since the sine and cosine are out of phase by 90 degrees these will modulate the reference voltage and the drive will know the angle of the shaft based on the unique wave form created by the sine/cosine wave interaction of each and the reference voltage. I attached a picture that kinda shows this.
I think I might try and find someone that has an encoder based Servostar and try to do a trade with $$. Then just put back the original Inc Encoder. This whole resolver business is a PITA... Thanks!
SFL
Old 08-26-2011, 07:55 PM
mike_Kilroy is on a distinguished road
we will help u trade if u want, we have lots of both, but u may be in worse shape doing that. what type of enc did the motor have? absolute? proprietary?> did if have the required halls or comm tracks? lots more wires and lot harder to phase not only motor but also halls now from unknown device.
resolver is a cake walk once u figure it out. ok. first things first. if fdbk circle goes around 2x for 1 mech rev of the motor(resolver) then yes, u have resolver poles wrong; this means u have a 4 pole resolver instead of the 2 pole u have picked in the software. make it 4 pole. gotta get the circle to match the motor rev first.
res expected is 50% transformation ratio; there are behind the scenes adjustments for this but 99% of the time that is not required.
if u can get 1 rev of motor equal to 1 rev of feedback page circle, then u can go to phasing it with the zero on command and rotate resolver by hand to line it up with motor pole.
but u need to know the no of motor poles to do this too - do u know? if not, count em: short 2 motor leads together and rotate it by hand counting the humps. this is ur motor pole count. once set in motor page then u can zero it.
enjoy
Old 08-27-2011, 09:25 AM
enjoy
I will give it another go on setting the pole count. There are some other things I was going to try. I found a technical update for the Servostar that updates the settings for MPHASE on AKM motors. I'd have to read it again to try and explain what it was referring to, but I got from it that it changes the Range of the feedback.
I am determined to get this thing working one way or another and I will document all of my goofs and victories here... Thanks for your help Kilroy.
SFL
Old 08-27-2011, 12:49 PM
sfl,
MPHASE wont make any difference for u: u gotta get 1 mech rev of motor/resolver to be 1 turn on feedback (PRD or pos res feecback) goes 0-65536 per mech rev. ck ur resolver specs u bought - is it 2 pole?? or 4 or 6? get the fdbk wheel right before u do anything.....
MHASE is 0 to 359 electrical degrees; which is 1 pole set. u will be using zero to make mphase=0 so dont worry about mphase.
call me mon morning if u want to talk abt it or pm or email me if u want more detailed help. u can do it!
Last edited by mike_Kilroy; 08-27-2011 at 05:49 PM. Reason: fix typo aphase to mphase
Old 09-07-2011, 11:52 AM
Kilroy,
It took a little while to get, but Tamagawa sent me the spec sheet on the resolver. I have it hooked up properly and I have a feedback. For some reason no matter what number I put in for pole count it still gives 2 electrical rotations for 1 mech rotation. Well if you could take a look at the PDF and maybe offer some advise I would appreciate it.
SFL
Old 09-07-2011, 11:58 AM
stay on and I will verify something by running one on my desk....give me 5 min to turn on my computer to talk to it..... do u IM? if so IM me?
Old 09-07-2011, 11:59 AM
Al_The_Man's Avatar
Won't you have to apply a gear ratio between motor and resolver for that resolver to match the motor?
Siemens and Fanuc motors used to use a miniature gear train.
Old 09-07-2011, 12:17 PM
Originally Posted by SuperFlyLoser View Post
Kilroy,
SFL
so u r good to go: ur resolver is 4 pole (2x) so it will go around 2x on the red feedback circle. By setting MRESPOLES (the box on feedback page next to red circle that says no of poles to 4, it setes it right internally, even tho the display did not get corrected - like all the other drives!
now u have to have the MPOLES in the motor page set properly to the no of motor poles too. once that done the system shud work if the res is setup to zero on a pole. im(those little icons on top right of the posts) me if u want and I can walk u thru it?
[IMG] code is Off
Problem- Error #5 resolver smithgrind Fadal 5 03-16-2011 11:14 AM
Need Help!- Encoder to Resolver ahmedrehan Servo Motors and Drives 2 08-21-2009 05:38 AM
z axis resolver Delw Fadal 4 06-26-2009 02:38 PM
Problem- C-axis resolver EPTech General Metal Working Machines 1 06-25-2009 08:04 AM
resolver removal will_lewis Servo Motors and Drives 2 01-05-2008 07:32 PM
